echappist wrote:
Your numbers simply don't add up. Considering that 50g of drag at 30 mph is ~7.3 watts (or 5.9 at 45 kph), 750g would be ~90 watts of drag at 45 kph.
If something is 15W faster at 45 kph, it suggests ~125g difference in drag. 20W would be another 160g difference; for a total of ~300g at 45 kph. So which one is it, 300g or 750g?
Perhaps you should stick to starting trolling posts and leave the technical stuff alone until you learn the basics?
Trolling: It was too soon wasn't it? ;-)
Yeah my numbers are effed, but it was all off the top of my head. I just had another quick look, and at zero yaw the F was about 970g, AR 790g, and IA was 640g. So the spread was more in the realm of 300g.
so based on your gram to watt numbers... (again quick math, and don't worry I am not giving up my day job)
45km/hr
F series: baseline (a frame with no aero consideration. Note that in the testing it had the same wheels/bars/etc as the AR... so non-aero frames are a huge penalty, no wonder modern road bikes are bending over backwards to add aero features)
AR: ~22w faster
IA: ~40W (~18w faster again)
30km/hr (I used 3.4x conversion of watts saved for 45km/hr to 30km/hr... calculator this time)
F: baseline
AR: 6.5W faster
IA: 12w faster (5.5W faster again)
As stated by another in this thread, modern road bikes are now narrowing the difference between them and an "aero" road frame. So the lines are blurring. An on the top end tt/tri bikes, further gains are becoming challenging. IF anything, trends to disc brakes and wider tires/rims is slowing down or reducing the performance of aero bikes (Aero road bike test from Tour Mag is one example, where in most cases older rim brake versions of a given aero bike were a touch faster than their new disc updates).
