JerseyBigfoot wrote:
I’m going to go the other way…
To successfully true wheels and be left with a strong wheel, spoke tensions need to be balanced. Getting a true and round wheel is the easy bit…
Something like the Park Tool spoke tensiometer is okay for home use, and about the minimum necessary tool beyond a spoke wrench. A wheel trying stand isn’t necessary, but it sure is nice to have. Get a Spokey or similar rather than buggering around with some multi tool spoke wrench that isn’t comfortable. It’s cheap and cheerful.
If getting the shop to do it is cheaper than the tensiometer, decide if it’s something you’d like to do. Personally, I enjoy wheel building and it is simple - as long as you’re methodical. Have fun!
Plenty of people have built and maintained good wheels without a tension meter. It's possible if the rim is good, the initial build is good, and the person working on the wheel recognizes that they should be making minor adjustments and spreading any adjustments over a broad area if possible.
The OP and everyone should also recognize that damage to a rim cannot properly be fixed by tightening or loosening spokes - the rim may end up true but very imbalanced and thus weak. A tension meter will demonstrate this quickly, but it's something that can be understood w/o one.
http://www.jt10000.com/
