ok seing though stuff is misleading, what I actually mean is the heat has to exit somehere so you will see it on the camera,
as this is thermal camera's iotis not light being reflected, it is the actual heat radiation from the object, in this case the motor.
in terms of where how they can be used, basically anywhere, it will probably be an issue to get an image of somone cycling past on a cheaper thermal cam, but if you were along side in a car it would be simple enough, certainly people coming into transition would be easy enough to check as you would not have ambient air cooling the frame so the heat being dumped from the core would show better.
that said the apps available for ipads etc that work of the compass would also be a fast easy check, prbably better than a themal cam for stationary checks, hell you could probably check reliably with one of those compases you get out of a christmas cracker,
I havent taken pic of a bike, but there are plenty on the net.
