dross wrote:
I have some older ”pre AXS” etap red crank arms that are 8 bolt pattern. Do you know if they should work with the AXS powermeter spider or AXS power direct mount chainrings? Sram said the chain line would be off, but I am not sure they knew exactly what I was asking. I don't want to by new crank arms if they are compatible.
Will be checking out your options on chain rings as soon as I put base the new bike.
On a side note, have you been able to do any testing with your wheels on a Cervelo PX? Any results you can share?
I think that yes, the chain line would be off as the new spiders are designed for DUB cranks only.
We do testing on our wheels in Cervelo frames as part of our protocol as they tend to reflect overall performance in other brands very well - we don't have published wheel data on PX series bikes (although we have had them in sessions under clients before), but I wouldn't expect anything different from what we've found in our published data.
AeroCoach UK
http://www.aero-coach.co.uk
