Is there any glaring reason not to use the new S-Works Turbo RapidAir tubeless tire on a XXX6 Bontragger rim?
Re: S-Works Turbo RapidAir compatiblity [DBF]
The rim needs to be Crotched. hookless is not allowed. And the rim cannot be too wide. The Bontrager rim is too wide 21mm inner with for a 28mm tire. According the E.T.R.O. standard the maximum is 17mm inner with.
Re: S-Works Turbo RapidAir compatiblity [marcelflash]
^^^ ahh no... 21 inner is not too wide for a 28 Roval whom is owner by specialized uses inners of basically 21 (20.9 or whatever) I doubt spesh would make a tire that could not work with their Roval wheelsets.. all the popular CL(x)32/50/64 are 21 inner.
gp5000 Tubeless work on it? Seems like the Bontragger tubeless tire is not so great.
Re: S-Works Turbo RapidAir compatiblity [spntrxi]
I am only stating the oficcial guidelines. Everybody can try for themselve. :)
https://bikerumor.com/...-width-best-results/
See ertro table within this article.
At least this shows some hookless rims are ok at a 28mm tyre.
But does suggest 19mm max internal width for a 28mm tyre for a crochet hooked rim.
Here is the compatibility chart from Specialized
https://specialized.picturepark.com/Go/BifLoWao/D/63465/1
The XXX6 rims aren't on the list but it does show it's compatible with the ENVE 4.5 AR which is a 25mm ID hookless rim. Based on that, I think you should be safe...but I'm not an engineer.
