Rotor 1x
Rotor makes a 1x ring, narrrow wide. Has anybody in ST land used it yet? Any thoughts?
Re: Rotor 1x [DBF] [ In reply to ]
Yes. I have for about 2 years. I have really liked it. Only had a couple times I dropped the chain. Had some links removed and I was good from then on. I haven't used any other 1X systems. I race in the flat lands of Houston but do Buffalo Springs 70.3 each year so I get a few short hills with it each year.
Re: Rotor 1x [trifit] [ In reply to ]
You using the narrow/wide ring or just a regular rotor ring?
Thanks
I race there single narrow wide on my CX bike. Love it. Only issues occurred when I had the wrong chain length
Any run that doesn't include pooping in someone's front yard is a win.
Re: Rotor 1x [CCF] [ In reply to ]
What have you learned about the correct chain length?
I'm putting on a 36t 1x narrow wide chainring on my wife's 3D+ crank/bike (This chain ring size is suitable for her as she rarely rides above 20km/h). I have her chain length currently set to a 2x 50/34 crank with 12-28 cassette, and I'm curious as to what changes to chain length I should make.
Same. If the chain is a little long (like two links), there's some sort of combination of the non-round shape, tooth profiling, or chain angle where I found the Rotor QX1 (in a 40 tooth) to lose the chain a few times in the 11 tooth. Bumpy ground, higher speed....drop. The exact same chain, chain length, cassette, bike, etc. with the 42 tooth SRAM CX1 ring has never dropped in thousands of gravel miles. I used that same QX1 ring with the shortest chain I could for two CX seasons and didn't have a single drop, no matter how hard I tried though.
Also had really good luck with the Absolute Black 38 tooth oval.
