DennisCelen wrote:
Nobody that can help me?
well it depends on many things
what do you want
what body shape are you where are you based usa vs europe.
so from your choice it is clear your want a suite that has loads of hip and leg lift all 4 are good for this.
if you are in europe the varman and the comp are the same price . the varman is the better suit the roka suit is the more robust suit. for myself the cut of roka is better so its hard to say. which of the 2 would be faster
i would say varman and pro aobut the same for me as roka fits better the varman likley a bit better lift .
so for me as a long upperbody athlete in the us i guess i would go for the roka pro in europe i would likely go for the varman.
and to be honest for the comp is hardly slower than the pro apart from getting out of it. iam not that concern ed about flexililty and roka cut fits me so well that even a comp feels very good. so including transition for me the difference for a half would be max 20 sec. if you only have one suit the comp much likly last longer.
so if the fit is right the comp is v good the pro is more forgiving as a bit more flexible but if this flexibility makes it you lose it could be slower than the comp
cant tell you much about the 4 my guess would its could be a tiny bit more flexible in the shoulder and a tiny bit less leg lift than the varman .
at the end if it was me i would order a varman and a pro if you want more flex in shoulder or want to save 15 sec over an half or the comp if you only have one suit and then keep the one that tests faster in the water .
for all the other 3 suits you want to have a training neoprene as they are to fragile for all season training.
also sizing in europe some roka pro siszes not available
