I haven't ridden or lab tested this bike yet, but I'd wager that it's doing a whole lot more than you think. I'd also wager that if you had paid for it, you'd feel it doing a lot more than it's probably doing.. our brains and perceptions aren't nearly as good at discerning things like this as we think they are.
The challenge with a bike design like this is that the rider will start to feel pedal induced bobbing below a certain stiffness for various components that will make the bike feel awkward and slow on smooth surfaces.. so just like with your tires, you need to have the bike above some level of stiffness to maintain more traditional pedaling dynamics and feel.
Typically we've seen bike stiffness (dropout to seat post measurements) in the 200-300N/mm range and recently some of the most comfortable of the current crop of race bikes is in the 120-140N/mm range. In my experience (pro rider body masses) the riders can be cool to about 60-80N/mm of tire or seat post stiffness (which will drive low system stiffnesses), if you feel yourself bouncing on the tire on flat ground, you'r probably down below 70N/mm. So if I had to guess on this one, I'd bet they are probably in this range for rear end stiffness with a design that allows for a higher degree of displacement in the frame.. which could be a big leap forward for this type of riding.
Since springs in series add like this: 1/a+1/b=1/c softer springs still dominate but bringing the stiffer ones down can also make big differences.
This is also what makes tires so special and unique, the spring rate of the tire is dependent on the shape of the thing is it sitting on or being impacted by, so that 28mm tire at 6bar has a stiffness of ~150N/mm pressed against perfectly flat road, 86N/mm hitting a large cobble with 8cm radius, and 37N/mm when hitting an 8mm radius.. source:
https://blog.silca.cc/...r-is-stiffer/harsher So back to our original example, say the old bike had stiffness of 140N/mm and your tire stiffness hitting a bump is 80N/mm, the system stiffness adds up to be 1/(1/140+1/80)=51N/mm and if they've set the rear end at say 80N/mm then the stiffness on that same impact would be 1/(1/80+1/80)=40N/mm which is more than 20% softer
Take that a step further, for a 600N impact force the system will result in 3 additional mm of travel for the softer frame (15 vs 12mm) which over time becomes a big deal.
http://www.SILCA.cc Check out my podcast, inside stories from more than 20 years of product and tech innovation from inside the Pro Peloton and Pro Triathlon worlds!
