I'm glad that you are comfortable with your PEARL iZUMi mountain bike shoes. Rarely are things a needed upgrade and cost is certainly a valid reason to not upgrade. Keep in mind that if you switch to a Road specific shoe, there is also the cost of pedals.
With that said benefits of switching to road specific shoes include:
1. Weight - This is both the saving in the shoe itself and also the road pedal
2. Connection - for the most part, road shoe / pedal interface is a more "positive" connection that a mountain interface. With a road pedal you are much more "locked in" with less toggle or extraneous movement
3. Adjustability - Road systems allow a wide range of fit adjustments. Cleat position, rotation and canting are often more than can be achieved with a mountain system
4. Stiffness of the plate: While many see this as the most important, I see it as the least. There is a good chance you will never feel an increase in speed or wattage due to the stiffness of the plate. However, in my opinion, comfort can be improved with decreased plate flex especially under high torque situations such as lower cadence out of saddle climbing.
Costs associated with switching:
1. Financial Cost
2. Ease of use: Initially road pedals can have a more difficult learning curve for clipping in and out
3. Float is decreased: Typically mountain cleats have more range of motion to wiggle your feet on the pedal. For some this is a benefit
4. Ease of walking: Lets face it, road cleats on smooth surfaces is always "exciting".
Dependent on which of the above points are relevant to you is whether you should make the switch.
Typically as people become more experienced in triathlon they gravitate toward road shoes and pedals. When this happens is up to you.
I talk a lot - Give it a listen:
http://www.fasttalklabs.com/category/fast-talk I also give Training Advice via
http://www.ForeverEndurance.com The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
