anakinpm wrote:
burnthesheep wrote:
Had a roadie crash involving the face. Looking to make informed purchasing decisions about replacing things.
Do road and TT helmets with visors offer any advantage here, or just added risk? (Giro Vanquish mips, for example, or any TT helmet with visors).
I did some Google searching. I just wanted to make an informed decision before replacing the destroyed helmet and glasses.
Also, any consensus on safest sunglasses design or coverage involving a crash?
Thanks.
I had a crash while wearing the Vanquish without the visor. It was one year ago on a winter day, so I wore the photochromic Oakley Jawbreaker. I hit an ice plate on the road and lost the control on the front wheel.. I didn't have time to even put the hands. I braked with my face and the jawbreaker broke on my face and nasal bridge.
I didn't like at all what the jawbreaker did to my face. That hard plastic they use in the frame... made me a scar I'll wear for my life. I'm pretty sure that if I was wearing the EV radar of the Vanquish visor reults'd be much better.
I'm attaching the picture of the glasses with the scratches and some blood on it... I can PM pictures of my face after the incident if you like.
Nah, that's ok! Seeing mine was bad enough.
But, I do think I will definitely go "rimmed" one way or another in the future. The larger flat surface that would contact the face seems like a better thing to me.
Seems like for visor helmets, I'd have to know if the visor is ANSI rated. It would cover more face, but wouldn't have a lower rim and would still "dig in". Could perhaps install some rubber trim around the lower edge of the visor to improve surface area/remove sharp edges I suppose.
Tucking your head in a crash isn't instinct at that speed or reaction time. There was a designer trying to add a hoop to a helmet to keep the face off the pavement, but doesn't look like it ever got traction.
I think a priority will be at least a forward facing camera. If I knew that someone took out my front wheel OR knew that I sprinted bad somehow...........that info would be worth a ton in terms of situational awareness in the future. I mean, I can assume both I guess...........but, there's only so many reasons you go OTB on a bike. The primary driver being the front wheel stops progressing forward at a rate such that you rotate over it. Whatever causes that.........
