Re: Official Speed Concept Owners Thread [IamSpartacus] [ In reply to ]
IamSpartacus wrote:
Sorry Mitch will repost here
Mitch just in regards to the mono plug in extension- I noticed that it has 3 holes running along the top each side for the arm cups/wing pad. The s-bends i use have the standard 4 holes. I also use the 4th hole to put wing/pads on (hole that is furtherest away from the body, towards the extensions). As a result, does this mean the mono would not work as it seems shorter? I have the s-bend bar just shy all the way forward but have hardly any room to go further forward. The arm cups are are in the middle of the wing. I have attached a pic, i hope it works. I want to try different bars, something like a zipp with 70mm rise, but im hesitant that i might not be able to get my pads in the right position (ie, quite forward) since the mono doesnt have as much length?
Looks like you got some great responses while I was out of town on the SC Owners thread, but as another mentioned, flipping the wing mount is my first stop. I wouldn't suggest flipping the bolt cradle (bolt assembly) to have the grub screw up front though, that is not something we would ever recommend as that screw is supposed to be in the rear only.
As for length, the standard mono and mono plug in will give you the same amount of movement - but that wing flip would help if you still find you need it more forward!
Mitchell Mathews | Community Manager | Trek Bikes
Find me on Instagram & Twitter @mitchmathewz
I am not certain you still wanted pictures or not but here is some images of my setup;
You honestly cant see the cables for the most part - they are hardly exposed. I thought about drilling the bar and running it through the front of the mono but really dont see the reason to do that.
Re: Official Speed Concept Owners Thread [teddygram] [ In reply to ]
Thanks teddy - i have the vuka 70 carbon on the way - looks like if you get the cut right and not have heaps of bar towards the rear, the cables exit the back and go into the stem pretty neat. No need for the mono-bar front holes.
How do you find the inward roll of the zipp bars? Must bring things pretty close up the top of the bars. I like your mount too, i normally use a k-edge tt mount which fits perfectly central to the trek bars....wont fit well with the inward roll of zipps, i will have to look at other solutions id say.
Cheers again, great set up.
I really like the roll on the bars - it positions my hands and wrists in a very comfortable position and they roll in very close where I can interlock my fingers and keep everything close.
What computer mount is that? I have the same setup as you but my garmin isn't centered due to the inward roll of the evo bars.
Re: Official Speed Concept Owners Thread [tonyg420] [ In reply to ]
It honestly is a cheap mount I found at Walmart;
https://www.walmart.com/...ter-Holder/480446005
I did some modifications to it but it’s all stuff any one with a drill and file can do. It comes with a go-pro bottom mount and I unbolted it and super glued the Garmin mount in place and then if I want to run a light or go-pro I have the option to bolt it back on.
That's a great and inexpensive solution. I'll have to pick one up, the crookedness of my computer, though perfectly readable, drives me nuts.
Re: Official Speed Concept Owners Thread [Mitch@Trek] [ In reply to ]
That’s interesting - I don’t think I’ve seen a single picture with the grub screw at the rear.
All the bikes I’ve seen (including mine) have the grub screw towards the front. I certainly haven’t knowingly flipped the cradle around.
Could you double check this for us please?
Re: Official Speed Concept Owners Thread [marting] [ In reply to ]
Perhaps we are talking about a different screw, but below is the screw I was discussing that I have seen flipped around (on the pivot cradle and labeled as "set screw"). I would leave it to the rear as the service manual recommends - but riders have moved it to the front to get more tilt of their mono extension.
My Trek LBS is adamant that the set screw can be in the back or the front, in fact they have 3 SC's on the floor, 2 one way and 1 the other. It solves real world customer problems to have the flexibility so people do it. I'm a rebel so mine is in the front.
Obviously some product engineer in the back of the building knows something about WHY the set screw should be in the back but Mitch can't say! You would think that if it was really that important they would have made it impossible to reverse it.
"Aquabike is a swim then sleep session on aerobars ...."
Thanks Mitch - your pictures are very clear. I'm now wondering how mine ended up back to front.
On a related note, I wonder if those who have had the extension bolts fail have their grub screw at the back or the front?
Re: Official Speed Concept Owners Thread [Fuller] [ In reply to ]
Mines completely rounded out - gonna be fun trying to get it out. Does this screw come with any bag of bolts or have a part number does anyone know?
In my experience with most of the failures I have seen the grub screw is at the rear with the mono extension pushed all the way forward and the arm pad/bridge very far forward on the extension bar causing most of the weight to be forward of the cradle pivot and putting stress on the rear bolt.
You wouldn't see this bolt in a kit, but it comes with the Pivot Cradle. No need to try to remove the old one. The part number is W331631 and it is an inexpensive part.
I wondered if that would be the case. Grub screw forward would relieve tensile stress on that rear bolt...
Mitch@Trek:
Is the mono plug-in really nowhere to be found? I reached out directly to Trek via online chat last week and the gentleman said he couldn't find any in stock. Seems like folks have been looking for this part since last summer! I bought a Speed Concept earlier this year and the reach is about the only thing I don't like about it. Would love to use my old Zipp Vuka extensions.
I’m confused, searched everywhere. What size/quantity DI2 wires do I need for a size med gen 2 SC? Will be doing the 2 button aerobar shifters, and brake lever shifters as well
Thanks
Bryan
Re: Official Speed Concept Owners Thread [Fat_Ironman] [ In reply to ]
Thanks
Bryan
These wires were fine for my SC gen2.
Re: Official Speed Concept Owners Thread [throxy] [ In reply to ]
throxy wrote:
Mitch@Trek:
We do have a new version arriving very soon - hang tight!
New version? Can you elaborate on what is different than the current plug-in mono extension?
blog
Re: Official Speed Concept Owners Thread [stevej] [ In reply to ]
Edited, see new post below.
This is great news!
Could you give a general time frame? Are we talking weeks or months, here? Would love to have this purchased and installed in time for IM Maryland.
Re: Official Speed Concept Owners Thread [ In reply to ]
For those asking about the new Mono Plug-In, I wanted to give you the official update which I can do now!
So the new model retains the same look, but uses 6 mm hardware over the previous 5 mm hardware for added strength. In order to run the new Mono Plug-In, you will need to order the following (which you can actually order TODAY!):
Mono Plugin – W582446
6mm bolt and T-nut – 596164
Mono Slider – W582447
6mm bolt and T-nut – 596164 (You will need TWO of these)
Mitch, can you please comment on what you guys changed on this and why? Is this an update to the 2 bolts on the tilt cradle? Is this backwards compatible with the previous mono plugin? Was this to address the bolt failures or fix the loosening of the extensions?
Parts just ordered through my bike shop. Thanks, Mitch!
