Appreciate the response.
With the carbon cockpit, I can copy the identical position I have with the aluminum cockpit correct?
Bike is completely clean, just need to figure out how to fit all that stuff in fuelcell, do you have a video showing how to pack. I do plan to use the fuselage for water, but planned to carry a bottle of nutrition in BTA, then this will also hide my garmin from the air.
I ride with a Rudy Project helmet.
I actually got upgraded to a S-works frame, but with expert components, so do I already have those bearings? So S works 2013 frame, but with components from 2013 expert, added fuelcell and sitero.
Is there an special type of rim that is optimal for this frame, or is wheelcover on carbon 90 MM with 90 MM deep front fine?
MattyElmore wrote:
Yoo CJAC,
You got some good advice to start with from dannyh above.
In terms of weight, start with the cockpit. We make an all carbon base bar with carbon extensions, and the adjustability for dialing in your position is bar none.
For aero, there are lots of things you can do. In addition to fit and things like that, i would start with making sure your bike/frame are completely clean of any nutrition or tools. Our SWAT line for tri ensures you have a place for everything without comprosmise. check it out
here. I would also suggest looking at aero helmets. Remember not all significant gains come from the bike, the rider is a pretty big factor as well.
Tires are also pretty key as mentioned, you want to look for something with less rolling resistence.
One other thing i'd look at is ceramic speed bearings, we offer these in all our S-Works bikes. This reduces fricition when pedaling.
Hope that helps, let me know if you have anything else, we're always happy to chat.
Thanks,
Matt Elmore
Specialized Bicycle Components
Product Marketing
