Its an Arundel cage. The 3T aero bars exit out the back of the base bar. I left a little space on the back side of the bars so that I could use the Profile Design mounts to bolt the cage too.
I was wondering the same thing lol. Been waiting for the fixed stem option to return for a while now but the Norcom is looking a bit more attractive (waiting for data) with several fixed FLAT stem options. Cheers.
B4MB1 wrote:
where did you get that stem?!
Flat stems (0mm rise) can be ordered now from your Felt Dealer.
i didnt want to drop additional coin for electric on the AR, even though toptube entry would have been nicer for shift routing. I like the glossy look, easier to keep clean looking and as we all know, red is fast, so I am going to have to dye what little hair i have left red as well. :) bike colors match team colors, lucky me, even though not team sponsor
SD............are those silly seatpost pieces necessary from an aero perspective? I am put them somewhere and not on post as i will use a different saddle come outdoor season and that may result in slight lowering of saddle. i though i saw somewhere that they were not. i guess they might keep sweat out of falling into post
No need to use the rubber strips. They just keep the inside of the frame clean.
AR3 EPS is the best way to get the most aero and lightest of the UHC Advanced frames. $5000 is a "steal"
Is there a certain language the dealer should use when ordering from Felt? I had two dealers try to order/pre-order the stem yesterday and they told me to call back in a few months.
Thanks.
Where are you located? The stems can be ordered from dealers in the USA with these part numbers referenced although I'd be surprised to hear anyone at the sales office is unaware of the update as we've been working on these for the better part of 18 months.
980100 - Stem Bayonet 3 Fixed Position 90mm x 0 980102 - Stem Bayonet 3 Fixed Position 110mm x 0
I would also like to know because I called to order a DA along with this stem and was told the same thing regarding the stem...
Cheers.
pkawaoka wrote:
Dave, Is there a certain language the dealer should use when ordering from Felt? I had two dealers try to order/pre-order the stem yesterday and they told me to call back in a few months. Thanks.
Are you in the US? Ask the Felt Dealer to reference these numbers:
My 2013 Felt B2, with some older components. I had a 2008 Felt B12 that got a crack in the seat post clamp and Felt hooked me up with this AWESOME warranty replacement.
2013 B2 Components - Frame, fork, headset, seat post, front and rear brakes 2008 B12 Components - Seat, wheels, Ultegra front and rear derailers Other - Ultegra crackset, 3T Mistral aero bars
Here's my .02 on the AR2. In terms of ride quality, I wouldn't compare it to other aero frames--I'd put it against any top of the line race bike. It rides and handles extremely well with great acceleration from stiff bottom bracket, and precise handling. It requires very little getting used to: just get on and go. For a race rig that's a nod to user friendliness. Initially the steering felt light, but after some descending it was an easy adjustment. Not twitchy or on edge like some bikes, which again adds to versatility as an all-arounder.
My winter bike is a BMC SLR01, which I've always considered to be very comfortable for a race frame but kind of spongy performance. The AR2 doesn't match in terms of pure comfort (nor does it need to), but is in a different league for handling and feedback. IMO it's on par with the S-Works SL4. I was going to keep the BMC to train and do long/tough races on but there's no need--watch for it in classifieds soon...
The other thing I like about this bike is the complete build package. It's well integrated and tight all around, with Ultegra Di2 and 3T cockpit. It's super clean with cables routed just on top tube just behind stem and battery hidden in seat tube. I've ridden the past generation Di2 a few times and the new one is steps beyond. Safe to say I won't go back to mechanical again.
One thing I didn't like on spec is the hidden Ultegra rear brake. It's not great, and that's a spot for possible improvement/upgrade. Also, this is more specific to my preferences but the wheels are interesting. Not exactly everyday hoops but also not what I'd want to race on. I sold them off and am replacing with Hed Ardennes + SL tubeless setup for when comfort is a premium, such as training and races like Battenkill. 303s otherwise.
Aside from those two nitpicky comments, two snaps for this bike. Safe to say it's my fav.
Side note: I switched out the Ultegra crank for my Red SRM. I'm waiting on new 11-spd chainrings but it works ok with 10-spd version. Ultegra shifted more crisply (no surprise there) but hopefully the updated rings will bring it closer.
Your stem was obtained by your bike's original owner directly from the company. Before others start calling up Felt, maybe it'd be good to point out who the "original owner" is.
Nice build! The comfort of that bike impresses me every time I point the bike down the dirt roads and fire at will. Glad you found the same.
How do you like the $300 sprint shifters? Dialing in the new shifting system to work as you want is a great way to personalize the performance of the Di2 system, too. The speed at which the multi-tap engages and the number of cogs that move when you hold down the button are all adjustable.
The 3T wheels were just part of the rest of the 3T package, the price is considerably less than the Zipp 303/404 option and I can't find a $6000 road bike that comes with aluminum wheels so the carbon hoops seemed to be the right spec. Wheels are getting to be like saddles anymore with guys buying condition specific wheels based on their strengths and courses. I use the Shimano C75 wheels but I'd never put them on a bike at the OEM level. The 3T wheelset is a good balance for an "all-rounder" I think. Using 50mm deep wheels has proven to be a bad choice when dealers try to sell bikes to novices on test rides in Texas during the windy season.
Make sure the rear brake is centered with the spring adjustment moving both arms at the same time. The cable housing needs to be free of any kinks so assembly must be carefully looked after. The brake will invariably have a softer lever feel than the front as there is more than twice as much housing so you'll get more compression. There are also more "bends" that get pulled straight when the brake cable is under tension so you lose a little lever travel. The rear quick release might not be needed if your rim widths are similar. A simple inline adjuster might do the trick. Run conventional housing from the brake lever to the inline adjuster and compressionless (Nokon, Jagwire KEB, Avid FlakJacket, Jagwire Link, etc...) housing to the rear caliper.
Totally get the wheel spec, makes perfect sense for price point. Can't really throw on everyday al rims and DAs or Zipps would get to pricey. Ironically, I've been on Prologo saddles for a while and like that one.
I've played around with the sprint shifting but haven't tuned it yet. I'm not much of a sprinter and probably not the best one to ask, but it is conveniently accessible. The shift speed was already about what I liked so it was a natural transition. Love how you can run up or down the cassette by merely holding down a button.
The rear brake is probably a matter of getting used to. It seems to have a "lighter" feel than Red, which is part of it. Although I did a double take when I looked down while riding and saw the brake arm sticking out so far. Second double take was when I changed rear brake pad and noticed it bulging from the middle because of the set screw placement. Couple swipes with razor sufficiently modified carbon pads but what type do you recommend for that brake?
