Pieman wrote:
I don't know what cda means, how to measure it, or how to improve it. I assume it means aerodynamic efficiency?
How would I go about trying to improve cda and therefore my speed at lower watts? Ride in the drops? Switch tires and tubes to Conti GP5000 tires and butyl tubes?
BTW, I don't really race much anymore, so trying to get faster on a specific loop I ride is the goal to keep me motivated when riding outside.
cdA is your coefficient of drag multiplied by your frontal area exposed to the wind.
For example, a cylinder ( round tubes ) are not aerodynamically efficient compared to an aerodynamic tube in the approximate shape of a tear droplet with a blunt leading edge, so the cylinder would have a higher coefficient of drag. Even if the frontal surface area is the same, the aero tubing is faster.
As the frontal surface area increases, eg the cylinder gets larger, so does cdA ( the area portion )
So the worse the shape, the more drag, and the larger the shape the more drag.
To improve these things, you want to do what you can to get slippery in the wind ( eg a good aero helmet, tight fitting clothing, shoes with less protruding buckles, maybe covers, shave legs etc. ) as well as try to lower your frontal surface area ( getting lower )
You have to find the right balance since you still want to be comfortable, and be able to generate power, not just fold yourself in half at the hip and hope for the best, so generally a good bike fit is a good idea. Some of the people on here can provide criticisms to a bike fit to at least get started.
Tires are a LITTLE different. Tire/rim SHAPE has to do with your aerodynamics, for example, you want the widest part of your rim to be 105% of the measured width of your tire in order to maximize aerodynamic efficiency of your tire/rim system.
However tire type such as the GP5000 generally comes down to rolling resistance ( essentially the energy loss in the deformation of the tire as it rolls ) GP5000 with latex tubes is a pretty fast setup, I run it on my road and tri bikes. There are a couple faster tires, but they tend to be more thin and fragile.
Power to overcome rolling resistance increases linearly with speed, whereas air resistance increases as a squared relationship with speed. ( eg, doubling your speed = 4 times the air resistance )
However power to overcome aerodynamic drag has a cubed relationship with speed. So to double your speed, you are producing 8 times the drag.
To increase speed 10% ( 1.10^3 ) you are looking at a 33% increase in the portion of power to overcome air resistance. Generally speaking 70-90% of your power output is to overcome aerodynamic drag ( faster you go the higher % )
This all shows why aerodynamics are so important in cycling.
