sp1ke wrote:
In the end I drilled the extensions and got the cables out through the bottom. Because I have mechanical shifting I didn't have another option other than routing them externally which would have sucked. I'm curious how the evo extensions work out (I went with regular ski bends). I decided not to use evos because of the inward bend shape and because I thought the tips would end up too close together. Post a pic when you're done ;)
stevej wrote:
sp1ke wrote:
Does anyone have any advice / pics etc... on how to cleanly route cables through the plug-in extension? I'm using Zipp Alumina Ski Bends but I don't see how to route the cables through the cut end without them doing an extreme bend. The Zipp extensions don't have other slots available so I was thinking about drilling a hole about 1 inch from them clamp mechanism of the plug-in mono and route the cables in that way. Being aluminum extensions should be fine... Any other ideas?
There really doesn't appear to be a perfect way. Just got my zipp evo extensions and was assessing how to route the cables. I'm either going to route it externally (covered up in mostly bar tape) and thread them through the holes in the plugin extension or route the cables internally through the entire bar and then connect it to the junction box on top of the stem cover with any excess cable tucked underneath the stem cover.
I'm sure when I go to execute, this will all change but that's my plan for now.
Forgot you mechanical. Luckily I have di2 so I have some different options. Going to start on it this weekend (I hope). I'll report back when I get it situated. I did a quick eye compare of the width between the two extensions (plug in verse standard mono extension) and I don't think it's too narrow for me. I used to roll my bars inward but stopped doing that when I got the newest sc as it didn't let me. The evo's come like they are already rolled inward so I don't think there is any need to roll them any more inward.
The one thing I need figure out is mounting my Garmin. I like my computer to be higher up towards my hands but the extensions aren't round there. Going to need to get an Alden design mount. Just need to determine the proper width.
blog
