Hi Ian
I'm looking to buy a Speedmax CF 8.0 and can't work out whether I should be an S or M - any help would be much appreciated.
I have previously been fitted to a Trek Speed Concept, size M.
My fit measurements are: Saddle height: 745mm, Reach (saddle nose to pads): 525mm, Drop: 95mm
I'm 5'9 with a 78.7cm inseam
I'll be switching the original cranks over to 170's as well.
Thanks!
Qudos,
I'm guessing your Pad Y is roughly 614 and your Pad X is in the neighborhood of 473. You'd be a medium in the Speedmax CF as well. You run a healthy drop so you might want to consider going even shorter in your cranks to 165.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com
I like the pursuit of mastery
Twitter - @TriCoachIan
Thanks!
Qudos,
Ian
Ian Murray
