Feedback on the Shiv TT (not other Specialized Shiv models, which are different bikes) It's fast....faster than the Shiv tri versions
Front end - the front end is a little difficult to adjust. When I was doing a lot of aero testing, I was able to get efficient at swapping out risers/spacers pretty quickly
- I have no issues setting up for a higher stack (set of risers/spacers) vs lower when I was doing shorter pure TTs.
- 100% agree Mike above that if you want angled pads, you need to do you own custom spacers/pieces.
- limited ability to adjust reach
- Can get really narrow , my current setup is so that the BTA barely fits, but was narrower doing road racing TTs
- no idea about different stems
Brake adjustment - front is easy
- rear is a pain to work on under the bike. But once set, no issues with swapping out narrow training wheels with wider race wheels
Wheels/Tires - I run clincher Zipp disc, 808 on front. no issues with 25s (Gp4000s, Corsa Speed). Used to race TTs with tubular version of same wheels
Other misc thoughts - Agree recabling is pretty straight forward. I am about to convert my bike to sram etap, will see how that goes
- look for a bike with a full set of risers/spacers as recommended above
- If you are going with a higher stack (spacers/risers) setup, make sure to use cross wing for stability
- I use a modified fuel cell for flat kit/nutrition, BTA and rear bottle for half distance.
- The Shiv TT does not have a bladder/internal water reservoir
Edit: I have not travelled with the bike by plane
