First off, I'm not questioning the Pose Method itself; I've never tried it nor read about it outside this article. However, the explanation of the physics behind it given in the review on the method contains some inaccuracies. As a physics geek I don't like to see physics misused, so here are the major things that stuck out to me.
At one point, the article states that the "minimum force needed to move the 70kg runner is more than 700n." This is simply not true. 700 Newtons is just the (approximate) weight of a 70 kg runner, so this is the minimum force needed to move the runner vertically. Since generally we're trying to move horizontally when running, the forward component of the propulsive force does not need to exceed the weight. Any net force on an object will cause the object to accelerate. That's what F=ma means.
These two statements also appear: "how can there be an equal and opposite reaction to driving yourself forward from your feet on a frictionless surface?" and "So, on ice where push off and traction fail, gravity (acceleration) and vertical ground reaction (support) succeed." To me, these statements suggest that the vertical ground reaction force is causing the forward propulsion of the runner and that (on ice) there is no forward component of the force. Force and acceleration are vector quantities, and the only force that can produce a forward acceleration is a forward force. Vertical forces can only produce acceleration in the vertical direction. If there was no forward component to the reaction force when running on ice, the runner would not move forward. I'm not 100% certain that the author intended to state that the vertical force was causing the forward motion, but that was how it sounded to me.
Just my two cents.
-Charlie
Just my two cents.
-Charlie
