heiko6376 wrote:
1. Do I need to install the bridge (holder for bta bottle) in any case for stability reasons? I would like not to install it but I'm not sure because i mounted 6cm of stack spacers under the armpads!
With that spacer stack it would be best to install the bridge.
Quote:
2. What is that item for that is mounted on the underside of your aeria stem?
This thread should give you a clue Quote:
(I would love to install rather than the bridge a plate that is positioned directly under the arm pads (like the tririg armpads). So I could hide the blip box under the plate. And the higher plate would be in the slipstream of my hands. Then I could also mount garmin higher for better reading)
What I've done for for some aerobars is have aluminium plate cut by waterjet locally (it's cheaper than CNC) in the same style as tririg with the bolt spacing specific to that bar. I'm pretty sure the first set of bolts are at 170mm width.
Quote:
3. Do you have a suggestion for mounting a blipbox as aero as possibile. Right know mine is mounted on the bta- bridge behind my garmin.
4. What will you show with the link you posted in one of your posts regarding the blipbox topic?
The link opens a site for carbon luggage!?
That was me trying to be funny by saying that the blipbox is so big that it needs a full sized suitcase.
I haven't worked with a blipbox to have any strong suggestions. If you have a bike with top tube mounts I'd be looking at putting the blipbox inside a Bento box - the ATTK IC is set up to make it easier to do this cleanly.
