Pro seemingly having come out with an awesome looking pair of bars here Vibe Aero Alloy Pursuit Handlebar | Pro Bikegear (pro-bikegear.com) and here
Vibe Aero Alloy Handlebar | Pro Bikegear (pro-bikegear.com)
One thing I'm stumped on though; what advantages do the pursuit shape have over the compact? they have a much longer reach (claimed 130mm but measured at 105mm by someone I saw) which means a shorter stem will then be needed. That works for me, would be 130 to 100 or 110, but is it worth it over the compact ones, where I loose out on the forward sweep and being able to go for a 36cm, but still can get a 38cm, with the same stem and it still has a slight (but not as much) flare to the drops.
Also, can I route my ultegra mechanical cables through these bars do you reckon along with my hydraulic hoses so they pop out by the stem, and are routed much more cleanly to there entry points in the down tube and front fork respectively?
