Hello Slowtwitch Joule Users:
Can you please tell me the quickest way to export data from a Joule into an Excel spreadsheet. All I want is three columns, time, power, cadence. Also, the data should not be smoothed in any way and I want maximum sampling frequency (1hz?).
The reason I'm asking all this is that I'm building a special purpose ergometer using a CycleOps Pro3 indoor trainer with powertap flywheel. It will be used offsite and it must be very easy to retrieve the data. If I can't make it work with the powertap + joule I can go with an old school tried and true wired SRM. That's not easy because of the special bottom bracket in those trainers.
Cheers,
Jim
Cheers,
Jim
