paull wrote:
So yes, its just a concept in physiology - an attempt to identify where LT is.
So you recognise that threshold is referring to physiological responses to exercise intensity. That's good. LT is but one of them but good that you see we are talking about
physiological threshold.
paull wrote:
Apart from that, ... it doesn't feel like a threshold,
Well I suppose that's a matter of opinion. When I ride at that level it most certainly feels like I'm riding on that edge. I'm not alone in that sensation but I suppose that's subjective.
paull wrote:
it doesn't look like a threshold, ..., its not visually identifiable as a threshold, its not mathematically identifiable as a threshold. But apparently, its still a threshold.
Well all of those are, frankly, wrong. I guess you've never looked at a chart plotting various physiological responses to sustained exercise intensity. Such a change from quasi steady state to non steady state physiological responses is most definitely visually identifiable, and it's also mathematically identifiable from physiological response data.
It's a threshold because it's the maximal intensity level at which physiological responses can maintain a quasi steady state, and above that intensity they no longer do.
paull wrote:
Its been shown on wattage (and not disputed) that the threshold is not identifiable from power data in the region 20 to 120 minutes.
No, this was not shown on wattage.
To reasonably estimate the intensity associated with this threshold all one needs is one decent data point in that range, i.e. a mean maximal effort of about an hour's duration. That will, for all intents and purposes represent a very good estimate of one's power at threshold.
That's because the duration maximally sustainable for various physiological thresholds is typically of that order. This has been shown repeatedly in the literature.
What such a data set (20-min to 120-min) does not necessarily reliably enable one to do is to use some mathematical models to identify threshold power. If you want to use such a model to tease out a threshold power value, it requires data from shorter durations.
But as I pointed out above, use of mathematical models is but one method of estimating threshold power. Do a 40km TT and you'll have a very good estimate.
paull wrote:
To calculate the threshold you need a model which proposes its existence
There is no need to propose its existence. It's a very well documented physiological phenomenon. It's established science. To propose otherwise would require an extraordinary amount of counter evidence.
Threshold exists, and there is an intensity level associated with it and it can be expressed as a power output.
paull wrote:
and uses short duration efforts to find it. i.e. even though it exists usually between 45 and 60 minutes, and you have data from 20 to 120 minutes, that would not be sufficient to calculate it, you need maximal data from 1 minute to 20 minutes also
Short duration efforts are required
if you propose to use a mathematical model in order to quantify each the various fundamental physiological capabilities, including threshold. One does not however need to use a mathematical model in order to ascertain a value for threshold power.
I'm not sure you'll take this in but really I'm doing this for the benefit of others.
The power we can sustain for any given duration is an integral of various physiological capabilities.
Some of these capabilities are sustainable for a very long time and are fuelled via an essentially limitless aerobic metabolism. While this power supply is not capacity limited it is somewhat rate limited - IOW this "threshold" capability can only provide so much power.
To go harder, this threshold level capability is supplemented by other non-sustainable but far less rate limited metabolic processes. These are significantly anaerobic in nature but it's a bit more complex than that, so let's just consider them capacity-limited capabilities which are far less rate limited - IOW they can supply significant additional power but only for relatively short durations. A little like a battery - it can discharge very quickly but there's only so much energy available. And also like a battery the rate at which it is discharged can vary - use it up quickly to service a very high power demand, or it can be made to last longer at lower (but still supra threshold) power.
So in order to ascertain this base level "threshold" capability
via a mathematical model of the power-duration curve, you need data that provides enough information about how much these capacity-limited metabolic processes are contributing to the total power output. If your data set only includes points at which such capacity-limited metabolic processes represent a small proportion of the total energy supply then you risk introducing error in estimates. Keep in mind that such models also provide more than an estimate of threshold power, they also inform about one's capacity limited energy supply.
With a good model and with good input data over a suitable range of durations, it is a very good way to parse out each of the fundamental physiological capabilities - in particular the sustainable component, threshold, and the non sustainable capacity limited component.
This parsing out is reliably done with mean maximal power data starting from a few minutes duration as in general for most people it represents a minimum duration one can fully expend their non-sustainable capacity - to drain that supplemental battery if you like.
paull wrote:
There is absolutely no way that a mathematician could take the high quality maximal power data of a well trained cyclist and identify a threshold without input from physiological models which create the concept of threshold. The shape of the power curve does not look at all like a threshold, it is a continuously reducing gradient from 5 minutes to way beyond 2 hours. In terms of pure data, it simply is not there, it does not exist.
Once again, threshold is a very well established physiological phenomenon. I'm not really sure why you dispute either its existence or the fact that one can ascertain the intensity at which it occurs via power data.
That you can't "see" it in an MMP plot is neither here nor there. Threshold exists and the intensity at which it occurs is most definitely ascertainable via power data (provided you have good input data and use an appropriate method).
http://www.cyclecoach.com http://www.aerocoach.com.au
