cbr shadow wrote:
Recently moved to the San Francisco Bay Area and would like to start participating in crits next year. A few guys that I ride with, who I consider strong cyclists joined their first crit this year (CAT 5) and got dropped before the end of the race. This was surprising to all of us, since I always hear CAT 5 is for beginners. It's possible that lots of really good cyclists showed up that day though, in which case this wasn't typical.
I'm wondering what type of power output I need to keep up with a "typical" Bay Area CAT 5 crit race. Right now my FTP is 255W. Long endurance rides aren't my forte, but quick sprints are.
What type of power numbers will I need?
For winter training I'm planning on going through TrainerRoad's Crit training plan along with (1) long ride on weekends.
-CBR
FTP is pretty much irrelevant. Your ability to go HARD for 20-30 seconds, recover and do it again (and again, and again) is more important. Also, your skills in being able to ride in the pack without wasting energy is probably what will give you and most other new bike racers the most trouble. If we cloned you and gave your clone cat 1/2 experience and tactics (but the same fitness), the cat 1/2 clone would probably think that it was an easy race and you might find it extremely hard due to bad positioning, using energy at the wrong times, not being able to move up without pushing a lot of wind, etc.
Back on the physical side, the difference between the effort level you're used to for even an olympic triathlon, let along a half or full IM is so different than what is required for a 40 minute criterium it will likely be something you just aren't used to. It will probably take some time to adapt, but you will adapt. Example, I upgraded to cat 2 by the middle of my first year racing. For the rest of that summer, every criterium I did was hit or miss whether or not I'd make it to the end. By the following season it was never a concern and I was able to be the aggressor.
Since you are in the SF Bay Area, make a point of going to the Fremont Early Bird criteriums in January to February. It's an easy, non-technical course and you will find the mentoring very helpful.
To your original question about power numbers, I'm kind of guessing, but I'd expect to see many bursts in the 500+ watt range.
One more thing is that if you are a "typical" triathlete who like to ride at around 80 rpm you will find it harder to adjust to the speed changes. Being able to spin your legs faster when the speed picks up a bit is a lot easier than having to stand up and push on a big gear just to pick up 3mph. If you can comfortably ride at a higher rpm I think you'll find the speed changes much easier to deal with.
Good luck.
Kevin
http://kevinmetcalfe.dreamhosters.com My Strava
