Hello fellow triathletes! I was reading this forum sometimes and recently came here again, when looking for possible causes of my Power2Max wobbling. The thread I was reading didn't help with my problems but I thought that maybe there are other Rotor3D24 users here that observed (or not) similar phenomena.
Long story short - i purchased Power2Max NGeco with Rotor 3D24 and Praxis chainrings directly from Power2Max and observed visible wobble since the first time I mounted it. It looks like that:
I contacted Power2Max support and the last message I got from them was "can you live with that?". I contacted them 3 times since but no response during the last 10 days. This is a major disappointment.
I tried to investigate the problem further and at least figure out if it's in the spider, cranksets or chainrings. I reconnected the spider perhaps 10 times and tried various FD settings but nothing changed. Chainrings and spider seem to be perfectly flat... But when I started looking at crankset, I found some odd things. The crank arms seem to be asymmetric, as seen on this videos:
https://www.youtube.com/watch?v=Eo9b4L8z__Q
https://www.youtube.com/watch?v=KsLAxloo6CM
I contacted Rotor support with that. They said: "contact Power2Max, case closed". Doh! Power2Max doesn't respond. Wobble doesn't stop and regardless of FD setting or trimming I get plenty of chain rubbing.
Perhaps there is someone with Rotor3D24 and can tell if this seems normal? I am thinking right now about purchasing another crankset and fixing it myself since Power2Max is pretty much useless
Thanks!
Przemek
Thanks!
Przemek
