Chris, Thank you for the advice. I tried the same thing this afternoon. I started by impairing existing devices then I set up the Viiiiva by pairing it to my ANT+ speed/cadence sensor and also to my iBike power meeter. Then I paired my V800 to the Viiiiva. It asked me for my wheel size and completed the pairing. At this point there was no indication that the hrm had paired. I then paired the ANT+ output to my Garmin 510 and I bike. I put the V800 in Bike mode and was concerned because it did not show my heart rate on the initial screen like it does with the H7. It just said GPS OK and bike OK. I decided to try riding anyway and pressed start.... And everything worked. HR, speed and cadence all registered on the V800.
In many ways it worked better than the H7 and BT speed/cadence sensor I was using before. The hr signal never dropped and the reported hr was always in a realistic range. With the h7 I would occasionally lose the signal and sometimes my HR was reported as way too high. Also with the JARV speed/cadence BT sensor, the V800 only recognized the speed sensor. With the Viiiiva, I got speed and cadence.
I do still have some concerns. I don't know why the Viiiiva can't be used only as an HRM. If I could do this then I wouldn't have to associate the belt with a single bike. Also it would be more usable if if showed the hr prior to the exercise starting.
That said... This is great progress and very cool. Thanks!
Mark
Mark
