Chris,
Is there a list of compatible devices from Polar? DCR has a good start to one, but it would be great to have an official list from Polar.
I took it to swim for the first time and this is what I noticed:
I set it on the "triathlon" profile as I have a sprint coming up in a couple of weeks. I tried to simulate it as closely as possible.
I waited on the side of the pool and I saw my heart rate displayed.
I jumped in the pool and lost my heart rate reading. After a short period (less than a minute) it registered again.
I saw 250yds and stopped. It appeared to have good HR reading through the swim. However shortly after stopping (with watch underwater) I lost HR reading again. I waited for it to establish a connection again. I then swam 5 sets of 100yds and when I stopped I kept the watch further from me which seemed to keep the connection up.
My last 250yds was good as well. My guess here is that when you stop and the watch is closer than normal, it will switch back to bluetooth (from gymlink) and temporarily lose connection until it goes back to gymlink? Is there a way to aways use gymlink instead of allowing it to connect via bluetooth?
The last thing I noticed. I simulated a 2 minute bike ride (with transitions between the swim-bike and bike-swim). I really like the way polar implemented this as if you press the wrong back button on a new leg, it makes you hold it for 3 seconds before it ends the session. (so if you accidently press the wrong button you will not have messed up your tri session).
The weird thing is after I hit back on the run, it didn't say I was done. Not being sure I ended the run leg, I pressed start again and ended up with another run leg. I would think at this point, polar wouldn't allow you to do that with the traditional triathlon profile.
All this was captured here: https://flow.polar.com/...ng/analysis/23132716
Thanks for listening...
Hi,
I picked up my polar v800 last week and so far have mixed emotion about the watch.
My latest issue is trying to use a speed/cadence sensor with the watch. I bought the Jarv speed/cadence sensor which was able to be paired easily with the watch. However when I select the sports profile no speed nor cadence was displayed. I then used the wahoo fitness app and both values were displayed with no problems.
I called polar who promised me a call back (I received none). I then started to play around with the sensor and watch. I deleted the pairing and re-paired the sensor which worked and I was able to display values. However when I stopped pedaling, the last values displayed never dropped to zero. I waited 5+ minutes with no change. When I started to pedal again, the numbers began to update. This did not occur on the wahoo app.
Next I walked away from the bike without ending my session (simulating a stop for water). When I came back the speed and cadence values were ---s. Starting to pedal again, these numbers never changed. When I ended the session and started a new workout, the values once again appeared. I am assuming this is not design intent. I really had high hopes for this watch, but reading some of the other posts I am not sure what to think now.
Larry
Hi,
Larry
