Ok, I'm stumped. Now I'll admit, I'm not the smartest when it comes to electronics, but almost every power meter I've owned has been so easy to connect. Rotate the pedals hard, hit "search" on the Garmin, and next thing you see is the ID number found.
I tried this with my new Favero pedals tonight and something is not working.
I've got a Garmin 1030. Activated the pedals with the app. The Garmin 1030 found the ID number for the pedals and they were now supposedly connected. Pedals are fully charged. Garmin is fully charged. Spin the crank arms and no power shows up. It still reads ZERO. So, I took the bike outside to stomp on the pedals a bit. Again, no power reading.
I started over, double checked the ID number for my pedals, and made sure the connected power source (on the Garmin) matched the ID number for the pedals (yes), and also used a second Garmin to connect. Both Garmins showed connected but the power continues to read zero on the screen. I don't know what I'm doing wrong because it should be so simple.
