RonanIRL wrote:
Thomas Gerlach wrote:
CompetiveCyclist is doing their usual seasonal discounting of their HED JET 6+ wheelset. Currently at $949 today. Really can't beat that price for wheels that are available NOW, not 8-10 weeks.Canyons are doing 25% off Zipp 303s and 404s. Do they run narrower than the HEDs?
There are two measurements. First there are the internal measurements. Zipp 404 Firecrest is 16.25mm, while HED JET+ is 21mm. The brake track however is very similar. HED is 25mm and Zipp is 24.73mm
Thanks Thomas, that's what I figured. I guess the only way to really know is to try and find someone with the same wheels? I can't find that article on tire choices but will the 23c tire at 85psi be wider on the Zipps or HEDs? I'm usually good at math but it's been a long day!
The tires will be wider on HED. For instance an old Supersonic 23mm could measure a tad over 23mm on Zipp and could between 24.5 and 26.5mm depending on how worn the tire is. As the tire is used the air pressure gradually expands the size of the tire.
