kevincoady wrote:
Thanks for the tip-- I picked one up! I might sell the Tarmac, GT Grade and Specialized Epic and just use this one with 2 sets of wheels. I would have done the same thing with the GT grade (love that bike) except that it only takes up to a 35 mm tire so it doesn't quite cut it as a MTB.
Now I just need to figure out what parts I want.
No problem...and for those of you who bought one, I've got a cable routing tip for those of you using cable actuated shifters.
The cable routing on this frame is only
mostly internal. There are replaceable cable stops for the shifters on the downtube for internal routing. Then, there's small holes near the BB where the cable is intended to come out, route over the outside of the BB, and then back into the frame behind the BB. Fishing the cables through those holes at the BB can be a bit of a pain. So, take a bit of time before assembling the bike to make cable replacement easier AND protect the cables in that exposed section. Here's how:
Before you install the BB, get yourself some lengths of the small white plastic tubing typically used inside of rigid-link cable housing (e.g. Jagwire Link). Route that tubing through the frame (and out and around the BB) first so that the tail ends stick out of the frame openings near the derailleurs. At the cable stop end, feed the tubing through the cable stop, cut it, and then flare the end (using a large nail tip, or something) so it can't drop past the opening in the stop. Now there's a continuous cable liner going all the way from the cable stop at the downtube through the openings near the derailleurs. What this does is keep the cables from being exposed to the elements under the BB, and also makes it infinitely easier to replace the cables when it comes time to do that. Feed the wire cables into the cable stop at the downtube, and they come out right at the derailleur openings.
Also, if you're using cable-actuated brakes, I highly recommend using Jagwire Link housing all the way from the brake lever to both brakes. The opening in the frame is easily large enough for the Link "beads", and you can place one of the rubber "bumper beads" over the links at either end of the frame openings to keep the length of housing from moving. Using solid housing links for the brake cables goes a long way to making sure cable-actuated disc brakes perform well IMHO.
