JoeO wrote:
Slowman wrote:
JoeO wrote:
I think that the distinction between "built into the crank" and "added on to the crank" makes the poll confusing. As long as I can use the crank I want to use, why would I care? Pioneer's PM is added to the crank but it's not like that gives you a choice of cranks
let me help. infocrank has a power meter embedded in it. you can't use the crank without the power meter, or vice versa. it's all one unit. pioneer is a power meter that is added to the crank. you can hold the power meter in your hand, absent the crank. you can use a crank and never put the power meter on it. there are multiple versions of each kind.
Well sure, I guess I can hold the Pioneer in my hand without the crank, but that's only if I buy it separately and only until it has been installed for the first time. Installation of the Pioneer is permanent. I can't ever move it to another crank. So I don't understand what difference it makes. Or rather, I don't understand why there would be preference one way or the other. It's effectively the same thing.
I'm not trying to be difficult, I'm just confused. Is there some power meter, that's added to a crank that I can then move to another crank?
here's the difference. to me. if you choose a pioneer, you're choosing a product made by a company that is only interested in electronics. it leaves the crank making to crank makers. pioneer doesn't need to be a cold forger, or a composites specialist. it only needs to worry about what it does, and then rely on shimano, sram, fsa, et al, to make cranks. then it responds to that tech by tweaking its product to match that tech.
infocrank says, wait, sounds great in theory, you're never going to get the accuracy you want unless you control the whole process.
i'm not taking a stand on which is best. but there is a clear difference in approach. the poll is designed to give you the latitude to choose the tech you'd prefer if you could have exactly what you want.
and, i recall the brim brothers attempt, and the polar attempt, but i have my doubts about whether we'll see chain or cleat tech in the future. nevertheless, that's why i placed the "other" button on the poll.
we never really talk much here about what you gain and what you give by where you place the PM. every time you choose a tech you either limit your ability to move that tech to another bike, or you limit the capacity of that component to do what that component is optimized to do. for example, yesterday we published on a time pedal. you like that pedal? great. then place your PM somewhere else. i think it's a worthy discussion to have; hence the poll.
Dan Empfield
aka Slowman
