Recabling my 2014 P3. Apparently I should remove the plastic bracket under the bottom bracket. Removed the single self-tapping screw but cannot get bracket off. Prying hard with flat blade screwdriver, any harder and I'll break the plastic. Is there a trick to this? Slide it maybe? Googled extensively and found no mention.
Re: P3 BB cable guide removal [garydunn808]
you mean 2013 p3? 2014 was NP3 and no screw needed on the bracket that very difficultly snaps in(I use needle nose pliers to grab it)
Re: P3 BB cable guide removal [jeffp]
Sorry yes probably 2013. Pliers, grab and wiggle? REALLY don't want to break it. Thanks for the reply.
no clue for you, just pointing out 2014 model did not have a screw
garydunn808 wrote:
Recabling my 2014 P3. Apparently I should remove the plastic bracket under the bottom bracket. Removed the single self-tapping screw but cannot get bracket off. Prying hard with flat blade screwdriver, any harder and I'll break the plastic. Is there a trick to this? Slide it maybe? Googled extensively and found no mention.why do you need to remove it?
Swimming Workout of the Day:
Favourite Swim Sets:
I have a 2014 NP2 and 2014 NP3. Both have a small screw on the BB cable guide. Still need to use a flat head screw driver to pop it out, though. Not sure what the screw does.
No coasting in running and no crying in baseball
