Richard Blaine wrote:
gmh39 wrote:
Hmmm. That's what I was afraid of.
Are the pedals reading the crank length setting from the head unit/watch, or is it something that is set up in the powertap app then just displayed on the head unit? If the former, my thinking is that I could use my head unit for my road bike and my watch for tri bike and have the crank length values for each bike set in the respective devices.
The length is set in the pedal by the head unit. So once you've set it once by any app/unit you're good. The problem is that most head units (at least the Powertap app and my Garmin 935) remember the length they last set to, so the value you see in a particular app/device may be wrong and confuse you (but again, this value won't be used if you use that app/device to record a ride). So better safe than sorry and set it whenever you think about it. I try to do it every time I move them to another bike, and to only use the Garmin.
Depending on which bike you are using, why not just set it to the primary bike. Let's say it is on the tri bike, then set it for the 155. Once on the road bike on 172.5, the power should just read lower by 11 percent (power = force x distance x RPM) of the real value....since distance is longer in this equation, you're just seeing a lower number than reality. Conveniently its around 10% lower so you can just eyeball it since really all you are worrying about is pacing.
To me this is like the difference between working out my cardio in different sport. Now that I am a swimmer, real swimmers are amazed by my impeccable pacinig at thee 1500m and and 800m even though I have almost no experience in these race.....but I have done countless 5K runs, and 15K bike time trial so even through the timing system is different, I know how to extract the right pacing out of my body.
So you could treat this as 2 sports. Tri biking measured in real watts. Road bike biking measured in a new unit. How about we'll name them fulcrum90 to denote that with this fulcrum your number is 90percent of a watt....problem solved. Should I submit this unit to Systeme Internationale so I can get my unit inserted beside James Watts'?
