refthimos wrote:
surfNJmatt wrote:
also which is cooler.
Wrong answer (to this particular question) without a doubt.
The TLDR answer to your question is go Aerohead unless you run hot or do races in hot weather - in either case, where ventilation/cooling is a concern. BUT if ventilation/cooling
is a concern, you are gambling if you go with the Aerohead. The P09 runs quite cool (for an aero helmet) sans visor and is the safer choice if heat is a concern.
Coolness was a secondary question. As with most users on ST, speed is often the number one determinant, the question asked was which one faster in the wind tunnel. In addition, the second question hasn't had nearly as much research as the first although I would love to see much more done, as a result it is much more subjective and thus unreliable to some extent. In my view, you are going to hear from a disproportionate number of people who feel it is hot (yourself included)
The reality is that some have tried to do some tests, Crowie being a great example, and did not find that helmet choice affected core temp. Core temp was to be more affected by hydration status than anything. Now I would love to see more on this topic, but regardless, Getting to T2 faster should help with the hydration naturally by both being out there less and also being out earlier in the day.The Aerohead can certainly feel warmer than my P09 w/o lens, but it isn't like a wetsuit where I literally reach down and let in water if I start to overheat.
Now, I agree we don't always get all the facts, requirements, and use-cases of the original OP. With that being said, I have never seen a helmet gain faster adoption in the pro ranks without some sort of sponsor support than the Aerohead. These athletes are arguably generating much more body heat and yet they seem to run fine.
Personally I would like to see more testing done on this subject, but yes, as it stands, I can't see any reason to go without an Aerohead. Last year I did Cozumel 70.3 and conditions were nearly unbearable and I didn't think the helmet was too hot. Again, I got hot so hot in the swim I wanted to rip off my swim cap. Never had that urge on the bike. I ran with a block of ice, for nearly a 1/2 mile at one point on the run. Core temp is much more greatly increased on the run than the bike.
Save: $50 on Speed Hound Recovery Boots |
$20 on Air Relax|
$100 on Normatec|
15% on Most Absorbable Magnesium Blogs: Best CHEAP Zwift / Bike Trainer Desk |
Theragun G3 vs $140 Bivi Percussive Massager |
Normatec Pulse 2.0 vs Normatec Pulse |
Speed Hound vs Normatec |
Air Relax vs Normatec | Q1 2018 Blood Test Results | |
Why HED JET+ Is The BEST value wheelset
