Original Tacx Neo (1) Setup Question
Hi All,
I've recently picked up the orginal Tacx Neo and having a moment trying to understand the cassette installation instructions.
The cassette i'm installing is : SRAM PG1070 10 speed
Part 3 of the instructions state the following: Determine the needed connector based on the cassette. Its starts taking about 'pockets' (No pocket /With pocket)
At this stage i'm not sure if i should be using a 1mm or 2mm spacer.
Has anyone else installed the same cassette on this Taxc Neo - and what size spacer did you use?
Many Thanks
(i've added pictures of the cassette, trainer hub and instructions)
Re: Original Tacx Neo (1) Setup Question [sambadhillon] [ In reply to ]
The cassette you have requires no spacer when used on a normal 10 speed freehub, it has a built in spacer.
so if you have an 11 speed freehub you will need a spacer.
Most Shimano 10 speed clusters on the other hand require a spacer when used on a 10 speed freehub, so will require an extra spacer when used on the tacx 11 speed freehub.
Re: Original Tacx Neo (1) Setup Question [lyrrad] [ In reply to ]
Thanks mate!
I used the 1mm spacer that came with the package.
Perfect.
All set for the long lockdown.
