I guess you could also apply this to helmets, get a BIG one and THICK helmet pads to fit your MEDIUM size head.
That said, I owned a Giant hardtail MTB bike which fit me like a glove ... and my current bike, while compact, is a 58 cm ... so Giant could size their bikes like, say, specialized and make many ... but if they can make 4 sizes and get rich doing it..................
Tom Demerly
The Tri Shop.com
Your right, it's not about cm's. It's also about body angles and center of gravity points (i.e., balance). It's naive to think you can just grab a bike and ride... period.
FWIW Joe Moya
Well, Mr. User Profile: QR guy
Status: Registered User Registered: Jan 7, 2003, 6:58 PM Last Logon: Feb 19, 2003, 5:40 PM Posts: 8 (0.2 per day) Real Name: No name entered. Location: No location entered. Local Time: Feb 19, 2003, 7:09 PM Email: No email entered.
O.K. ...I believe you... but, (trust me when I say) your not saying much.
And, I truely didn't mean for my comments to be taken personal... If I had known you were sensitive (and, I'm not being sarcastic), I would have not used such a harsh word as "Naive". For that I apologize, but for gawd sake don't start swinging until ya' know whose butt ya think you can kick... that kind of tact can get REALLY embarrassing. What if I'm a paraplegic athlete? ...hmmm, enough said.
Joe Moya
"No one can make you feel inferior without your consent" - Eleanor Roosevelt
As to your statement about... "would only a few cm' make a difference." Don't know... it seems tolerance is dependent upon what is incorrectly fitted and whom it fitted. (IMHO) The tolerance level for errors are dependent upon where the error is made and what are the physical limitations of the athlete. Some riders can tolerate a wider range of fitting error. While others can tolerate a wide range of fitting error in some locates but can't in other locations. As for myself, I can tolerate a large difference between stem height and seat height, but have little tolerance for incorrect seat height and position of seat - a few cm's off and the comfort level goes down significantly.
As for the little differences, I agree, sometimes their importance is a bit overrated... but one riders little difference is another bikers major difference in quality of bike fit. Whether or not a pro-fitter can see the difference is not defined by matching there fit exactly isn't the point. (IMHO) The pro-fitter should be able to determine the tolerance levels and margin's for error for the same biker under different circumstances. And, quite honestly, I don't believe a bike fit can be determine in just one fitting. It's really a learning process that occurs between the rider and the fitter. The rider defines what is working and what is not. The fitter's job is to use his experience to find a solution to those problems or improve on those attributes. And during that process, sometimes only a few cm's does make a difference... and sometimes, it is a useless detail.
FWIW Joe Moya
