lbmxj560 wrote:
Cookiebuilder wrote:
A ton of people have this problem including me. my kickr is 10 higher than my vectors my old vector were 25 differnt, my buddys power tap is 25 different .. but my kickr is a consistent 10 so no big deal my ftp on tr is based of the kickr. no need to have them match. don't do the power match stuff you have a trainer, test with it then train.I just don't agree with this at all. Absolutely 100% ALWAYS use power match. If you don't all you've got is two expensive bike components that only work in limited circumstances (the trainer indoors and the power meter outdoors) telling you, potentially, different things.
The whole point of power match is so that the power you work at on the trainer is the same power that you work at outside. I have a smart trainer and a power meter and not once have I ever worked off the power given by the trainer, there is no point. I use my power meter to control the output of the trainer. That way I know that 250 watts inside is the same 250 watts when riding outside. I don't have to do any calculations to work out whether I need to add or subtract from my power for it to be accurate.
Power match is dead simple. Connect your power meter to trainer road. Connect the smart trainer to trainer road. Tell trainer road (in the settings) that you want trainer road to take the readings from the power meter and power match. Trainer road will then display the power from the power meter and adjust the trainer accordingly. Done.
Correct.
However, if using Pedals linked to TR via Bluetooth it only reads your left pedal and doubles it. So that can present accuracy issues as well. Need to connect via ANT+ to get the true power, left and right. Especially since most people have imbalance between legs. Mine is 54 left and 46 right. So my power is slightly inflated.
