Re: Official Speed Concept Owners Thread [plant_based] [ In reply to ]
plant_based wrote:
thinking of going to GP5000 700c x 25 tires and just hope they fit.
This is what I run and fit is good.
http://www.sfuelsgolonger.com
http://www.endureiq.com
Re: Official Speed Concept Owners Thread [timr] [ In reply to ]
Thanks!!!
https://www.strava.com/...tes/zachary_mckinney
Re: 10,000 posts - new record? [cloy] [ In reply to ]
cloy wrote:
I'm wanting to experiment with my fit a little bit. Is there a shim I can get to independently raise my arm pads? I'm on the low/far stem and the highest bar spacer right now (45mm?). I want to play around with something slightly higher but don't want the headache of swapping the stem and spacer right now. Thoughts?
Cut up an old yoga mat into a bunch of pieces same shape as the trek arm pads. Tape a bunch of layers on to the top of existing arm pads to add as much height as you want. It won't help in raising the ends of the extensions, but will at least let you experiment with higher pad position. Could also tape a small extension of something, anything, to the ends of the extensions to simulate the height there too....
There is a 5mm pad spacer you can install under the pad wing - part # 327606
You can also flip the pad wing if it isn't already upright!
Mitchell Mathews | Community Manager | Trek Bikes | @mitchmathewz
Re: ***Speed Concept Fit Guide*** [Mitch@Trek] [ In reply to ]
Hi Mitch,
Could you point me to the best frame size + stem set up?
Arm pad reach (BB to back of pad) 512mm
Arm pad stack 680mm
Saddle height 821mm
Thank you
Kodi
Angled spacer [ In reply to ]
Hello,
I've searched around and can't find any so I suspect the answer is no. However, do any of you know if there is any kind of adapter or angled spacer or other aftermarket solution that will allow a greater range of tilt for the monobar? I did see some that angle the arm pads but looking for something that will angle the full monobar.
Cheers,
Chris
Re: Angled spacer [chrisone] [ In reply to ]
You can flip the pivot cradle 180 deg so the set screw is more towards the front of the bike. That will get you more tilt of the existing mono bar. If you haven't done so already, get the mono-plug in so you can run any extensions you want. You can get regular ski bends and then mount them on the opposite end to get your hands super high and close to praying mantis position.
blog
Re: Angled spacer [stevej] [ In reply to ]
Anyone have any insight when the new SC is coming out? My LBS can't get a definitive date. Perhaps they are waiting on Shimano's Tuesdays release. Maybe a 70.3 Worlds release?
blog
Thanks stevej. Do you happen to know what kind of angle is achievable by flipping the pivot cradle? I'm looking to try and replicate my 15 degree setup from another bike.
Given that their existing models, like the madone, have been showing 400+ days out on the dealer website, I wouldn't hold your breath for a a new model to actually be available any time soon. They might 'release' it, just like argon 'released' their new e119, but actually getting one, I'm betting 2023.
I never measured it but you should be able to achieve 15 deg of tilt with the pivot cradle flipped and some high rise extensions.
blog
Re: Angled spacer [SBRcanuck] [ In reply to ]
Yeah I'm not too concerned about the lead time as I know it's going to be long and out of my control. I know certain sizes of various models have smaller lead times than other sizes. Just spoke to my LBS owner this morning on a ride and he just ordered a few madone frames that currently show 4 weeks. I
I just want to get it in the cue regardless of what the lead time is.
blog
I’m in the same boat. I want to get the new one as soon as I can, even if that turns out to be 2023.
Re: Angled spacer [mitchellgsides] [ In reply to ]
Ditto, will jump into the P1 queue for a SpeedConcept Disc when it opens (or stock if that's the only option). I can ride my Wisc built SC until then
I have seen one. The triathlon version at least. They are a site to behold. They are coming soon. No clue about lead time, etc.
Re: ***Speed Concept Fit Guide*** [KodioMN] [ In reply to ]
KodioMN wrote:
Hi Mitch,
Arm pad stack 680mm
Saddle height 821mm
Thank you
Kodi
Sorry for the late reply!
You're probably best fit with an XL frame, Medium-Far stem, and a 15mm Mono spacer. I would also run a Long seatpost with a 50mm offset if that saddle measurement is to the rails. If it is to the top, you can run a Long seatpost with a 15mm offset which maxes out at 820mm to the rails.
Re: Angled spacer [Rideon77] [ In reply to ]
So we've all seen the UCI version under pro riders........what was different about the tri version?
Thank you, Mitch.
Cheers
Compared to the current SC, not the new UCI version: Hydration and flat repair kit integration, seat stays, and cockpit. I only got a few min to look at it and no pictures but that's what I remember. They were coy on the official release date as you can imagine so I don't know the real date other than "soon" (when ever that means).
the Tri version looks 90% different than the UCI one we've seen. The only thing similar is the rear brake design area. Everything else is totally revamped. The things mentioned above are true. Sick paint jobs. But the most stand out feature is ISO Speed! Can't wait!
Re: Angled spacer [sigmachi] [ In reply to ]
Thanks. You and rideon77 are making me want to see this thing. Any idea on price points? Will it be like specialized and have crazy prizes and no option for us less wealthy people?
Hoping they have tiered prices and packages.
ooh, isospeed has me interested!
the #1 thing i dislike about my SC is that it feels rough and stiff on our chipseal roads, yet has a dead unresponsive ride feel (both as compared to my venge which is probably nearly as low drag in terms of the frame). isospeed would at least address the first part of that
Yes I forgot about the ISO speed. That will be interesting to see how that really works with ability to "dial in" comfort and fit. The paint job was sick and it was close to the colors of my current SC. (Yay me!). I see myself parting with some money soon.
Bontrager Comp Road Pedal on SC [ In reply to ]
Mitch,
Question related to my Bontrager Comp Road Pedals I'm putting on my new SC (since y'all own both brands).
There is an adjustment screw for engagement resistance. As I lessen the resistance, is there any potential the adjustment screw can come all the way out/fall out? Even on the lowest resistance?
Thanks!
💀 Fxck Cancer Endurance Team 💀
⚡️⚡️ PLUSH Global ⚡️⚡️
Re: Bontrager Comp Road Pedal on SC [JakeLikesDonuts] [ In reply to ]
To my knowledge, it is a screw that can be fully removed, so you will just want to make sure it isn't fully hanging out. I tried to find a drawing of the screw to confirm this, but didn't see one in my view. I would not expect it to fall out though, it is under tension and should stay in place.
