dannyh wrote:
It sounds like it could be the same problem. I would take it in and have it checked.
As for my bearing mystery its just a pressfit bb30 where the plastic cups need to be glued in with "3M Scotch Weld - Epoxy Adhesive DP-420" The service tech said it would be $40-50 for him to do it and i could do it but the epoxy alone costs $25 at Grainger...
I hope this helps
Danny
And how exactly will you ever change out the bearings? This sounds like a terrible idea.
The bearings seem to be more of a slip fit than a press fit. If you get creaking, just disassemble the crank, pull out the bearings if they are loose, regrease all the contact surfaces and reassemble. I've had to do this a couple times, seems to last a few months of riding unless riding in wet conditions. But mine is possibly a bit worse since I'm also running the enduro adapter with shimano cranks so there are a couple more interfaces that can introduce some creaking.
