That's a pic of a service center calibration rig which requires a tighter tolerance because we're setting slope AND intercept via the fixture while the Joule simply reports back what the rig is telling it. If you for some reason have access to this rig and are seeing 535 our protocol dictates you would reject this unit and replace the torque sensor. In the field, however, you really are only seeing an offset value (535 in your case) and being within a specific range is not nearly as important. That being said, we often use these values as an INDIRECT indicator of general system health. In other words, a hub that displays a zero offset of 300 instead of 512 can still perform perfectly but the fact that the system has to "tare" or create that large of an offset is an indicator that it is compensating for something and typically speaking when this is the case the offset changes by large amounts, frequently.
So, bottom line is that the offset value is only one aspect of system integrity. In addition, you need to take into account the stability of that number (does it change daily despite relatively similar conditions) and by how much does it change?? Of all 3 of these factors the rate and frequency of change is far more important than the value itself.
All this being said, we're happy to check calibration on any PowerTap systems and provide a diagnosis via one of our dozen or so global service centers.
But 535 is out of range (unused hub) , What should I do?
Jesse Bartholomew
gdellamattia wrote:
Thanks Jesse. But 535 is out of range (unused hub) , What should I do?
Jesse Bartholomew
