tfizz,
TL:DR - this bike will fit you. The stem has to be level to the ground in the -17 degree position to make it work and probably little to no spacers under stem or pedestal under aerobars.
The very best way to purchase a tri bike is to go to a fitter than has all of these things: tri fit education, tri fit experience, and a dynamic fit bike (there are only ~5 of these [guru, purely custom, exit, muve, shimano], they are specific to the task). The fitter has to have all three of those things - they can't get by with just 2 out of 3. From that pre-fit process the fitter would have you leave with 2 things: 1) your Pad Y and Pad X. These are the numbers by which we identify bikes that will fit someone. And part of this should be a list of 3-5 bikes that interest you, the size in each brand/model that is right and the front end configuration - where we would put the pads in the right spot for you. 2) All your fit coordinates: seat height, set back, cockpit distance, arm pad elevation, etc. etc. etc. - and for tri there are lots of coordinates to name.
You may have had that experience and we're just not getting the numbers of out it properly. Maybe not, I don't know.
The next best way is to take your old tri bike that has a very good position and measure Pad Y, Pad X off that to identify the new bike but you don't have that. As you said you're new to the tri purchase.
The third best way is to give some details about your morphology to me and let me make an educated guess. This works because we're all human and pretty much the same. If both you and I are rushed to the emergency room in need of an appendicitis they don't cut me above my right hip and cut you above your left clavicle. We're all pretty similar to an extent.
You've got long legs for your height. That's an important detail. I think, based on what you've given me, your Pad Y is somewhere around 625 and your Pad X is ~450. This is assuming you're long leggedness is the big issue to take into consideration, there could be other factors that might impact this (lots of fused vertebra in your lumbar, a round belly that resembles the 7th month of a pregnancy) - but if you're pretty normal than I'm confident with the Y at or near 625 and Pad X roughly 450.
You have a 54cm PRfour... we can get close to this on your bike in three different ways.... here we go.....
- 54cm PRfour with a 110mm stem set up in the -17 degree position. Slammed - by this I mean no spacers under the stem, no pedestal under the arobars. Then the pads mounted one hole forward of the absolute middle.
- 54cm PRfour with a 90mm stem in the -17 degree position. Slammed and pads 3 holes forward of all the way back.
- 54cm PRfour with a 70mm, -17 deg stem, slammed, pads mounted dead center.
If I'm right about the Pad Y then you cannot get that low with the current systems in place*. But you can get close. The lowest you can get is 636/637 (#1 & and #2 above yield 637 and #3 above gets you down to 636mm of Pad Y). That's 16mm higher than I'd assume you ride BUT you might LOVE IT there. It might be perfect. You might even ride higher at 642 or 647 and your bike can meet you there too. Quick side note - the stem cannot be flipped to the +17 position to get even close to these numbers: the lowest the bike goes with the +17 is 680ish. Now, If I'm right about the Pad X then you've got it made because all three of these stems hit on or with/in 1 mm of your Pad X - and there's room to move longer or shorter in your cockpit if I'm off a bit in my guestamation.
*Let's say for a moment that I'm right about the Pad Y being 625...or even, dare I say, you absolutely must ride even lower at 615ish. This bike could still get there. I'm not nuts about what I'm gonna propose but I feel I'd be remiss if I left it out. You could get a stem that's even more angled down than a -17. That's one option. The other is that you remove the clip on aerobars that came with the bike and you installed a set that can be "under mounted" so that you have arm pads that are essentially resting on top of the base bar. This whole paragraph is prolly unnecessary.
There is one thing that is mandatory for all this to work. You must be riding a tri saddle and you must be riding it comfortable in the proper spot (on the front 3/4 of that saddle) for all this to work. If you're ride a road saddle or a tri saddle and sitting way back on it then these numbers won't be close and your position isn't right. The correct saddle for you is critical for success.
Get back to me here with questions.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
