Quote:
Good stuff.
I’m curious the. Why the 54 recommendation for the Five, but 52 for the Six? Should it be the other way around? If the 54 in the Six would get me down to 620, that’s a full 30 lower where I am now, which I doubt I’ll ever got that low (I’m not exactly high now either).
Whereas the 54 in the Five would only get me down to 637 if I’m understanding correctly.
If it further helps I’m 6’1” with a 32in-ish inseam when measured by a tailor (I wear 34” pants, which aren’t leggy at all. 32” pants end up being borderline high water pants).
blueapplepaste,
Pad Y of 650 to 630 - I didn't consider that a "little lower". I should have asked for a definition of terms. I'd be super curious to know what length crank you're riding currently.
Here's my though process...
In terms of Pad location I'm good with 3mm too long or too short, and I'm okay with 2mm too low or too high. I feel like those are acceptable variables. To that end...
The 50cm and the 56cm PRfive cannot deliver the 645 Pad Y so they, along with the 48 and 58, are not in the consideration.
The 52 PRfive can give you a 645 Pad Y with a 70mm & 90mm stem but that set up isn't long enough.
The 52 PRfive can give you 645 in Pad Y with a 110 stem but then the 500 is X is the longest the bike will go. Yes, if you go lower, you essentially slide down that 73 degree angle and buy a couple more millimetres.
The 54cm PRfive offers the best combo of your Pad Y and Pad X. You ride pretty long already and you say you want to ride a little longer...okay, the 54cm PRfive is your bike. If you want to go a lot lower (635 or below) then you need to go to the 52 but it'll limit you a bit on the length.
Now the PRsix.. that bike will deliver on your Pad Y and Pad X in a size 50, 52, 54, 56. The 50 and 56 don't offer that much wiggle room.
If you go with the 52, it's the script I wrote in the previous post:
Quote:
110 stem. Stem/bar clamp in the "high" position (meaning the two clam shells are under the bar within the clam) and 25mm of arm pad pedestal. Pad bracket in rearward position and pad mounted in rear hole.
If you go with the 54, it's this set up: 110 stem. Stem/bar clamp in the low position (meaning the two clam shells are atop the bar within in the clamp) and 25mm of arm pad pedestal. Pad bracket in rearward position and pad mounted in mid-rear hole.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
