Ian,
Thanks for the VERY detailed respose! I can't thank you enough. But I'm a bit confused......I had dissected my numbers myself and would have put muself on a 52cm with either the PR5 or PR6, I'm a numbers nerd but no pro hence I go see the best fitter I can find. My fitter just threw me a curveball and sent me over an email stating he liked the idea of a 54cm PR5 with a 90mm stem and minimal spacers below stem and 20mm pedestal under pads (the most I am personally comfortable with). I am certainly NOT discounting anyones opinion, I am trying to be as informed as I possibly can to make the best decision I can for myself. Does your opinion change at all if I tell you that I made a mistake and one I forgot to add the 20mm (Measured with 100mm stem when it should have been 1200mm stem. Yes that how poor The Plasma fit me) and specified that my 426mm Pad reach was to the back of the bars and should actually have read 446 and my mid pad reach was 488mm? Does this look a little more normal morphology? HA! And thank you very much for the suggestion of the 155mm Crankset, It was discussed during my fit session. I would have not have thought about asking for it at point of purchase through QR!
So it should actually read
Pad Stack 659
Pad reach 446
Pad reach mid pad 488
Saddle Height 767
Saddle Setback 11
Saddle to Pad Drop 155
Saddle to Pad Reach 483
Grip reach 742
Grip drop 82
Grip angle 48
Arm pad to grip 347
BB to Grip 773
Arm pad Drop -100
Pad reach 426
Saddle Height 767
Saddle Setback 11
Grip reach 742
Grip drop 82
Grip angle 48
Arm pad to grip 347
BB to Grip 773
Arm pad Drop -100
mpkellyjunior,
There's some good info in here (beyond the numbers), thank you - the more I know the better I can prescribe. You're leggy and that makes the reach aspect of your fit short and it complicates things slightly. I fit lots of people built like this, I'm built like this so don't freak out when you, a guy who's 5'11", the frame size I'm about to lay down here (it's 'cause of your morphology and that 426)
If you get a QR PRsix (the super bike) it's a a size 50, with the 90mm stem, the stem clamp shell in the "high" position, 65mm of pedestal, arm rest in the middle hole with the bracket rearward.
If you get a QR PRfive or foure it's a size 52, with a 70mm stem in the -17 configuration, with 10mm of armrest riser, with armrests mounted one hole back from middle.
Now, with the hip focus - combined with 100m of drop - I want to suggest...nay, insist that you go with short cranks (155s). One option is that you call QR within your order and get a set of Rotor 155 cranks installed on that bike before ship. Later, if you l like you can get Rotor's new INspider powermeter worked into that.
I'm here if/when you have questions, comments.
Ian
Pad Stack 659
Pad reach 446
Saddle Height 767
Saddle Setback 11
Grip reach 742
Grip drop 82
Grip angle 48
Arm pad to grip 347
BB to Grip 773
Arm pad Drop -100
ianpeace wrote:
Quote:
Pad Stack 659 Pad reach 426
Saddle Height 767
Saddle Setback 11
Grip reach 742
Grip drop 82
Grip angle 48
Arm pad to grip 347
BB to Grip 773
Arm pad Drop -100
mpkellyjunior,
Ian
