Quote:
Hi Ian,
I recently bought a 2nd hand 2019 Prsix in size 56, which was a bit of a gamble, but long story short my previous bike was stolen and I needed a race bike fast. I have had a fit, which fits me on the bike, but I am unsure whether I should persist with the size 56, or sell and move to a 54, which I believe would be better. I did check the QR website first and they advised I could pick either the 54 or the 56 (height 6ft). My main problem is that the seatpost seems extremely low and everything is set back more or less to the limits (bar, extensions, seat etc), and I am unsure whether it is too low or in a position feasible for the long term. Other than that I am sitting comfortably and have no issues when riding, and am able to generate race power no problem.
My retul measurements after the fitting are as follows -
Saddle height 737mm
Saddle Setback 3mm
Arm Pad Stack BB 666mm (I have since added another 40mm spacers to this)
Seat Tube Angle 80 degrees
Frame Stack 561mm
Frame Reach 436mm
Arm Pad Reach Saddle 544mm (I have since changed arm pads so this is effectively around 520mm)
Handlebar Stack 598mm
Handlebar Reach 547mm
Do you think it is worthwhile persisting with the 56, or would I be better selling and getting hold of a 54. I can probably get back what I paid so there is no financial penalty.
Thanks,
Ian
Ian,
Retul has some terms on their fit report that create confusion. I need Pad Y to prescribe (and to answer your questions) and you've given me exactly that: "Arm Pad Stack BB 666mm (you've added another 40mm since then). I also need Pad X and it's NOT "Arm Pad Reach Saddle 544mm" - it's probably something like "Arm Pad Reach BB". Now maybe.....what I'm about to do is dangerous...maybe it's 541. I'm guessing at that because the nose of the saddle is 3mm behind the BB ("setback 3mm) and if I subtract 3 from 544 = 541. MAYBE. I'd like to know for sure so get back to me here, but I'm still gonna riff on Pad Y of 706 and Pad X of 541.
So, as to the size 56 you have now....
If your Pad Y is 706 then you have one of three possible configurations:
1) The stem/bar clamp is in the low position (both clamshells on top of base bar) + 65mm of pedestal
2) The stem/bar clamp mid (one clamp on top, one on bottom) + 55mm of pedestal
3) The stem/bar clamp high (both on bottom) + 45mm of pedestal.
If I were building this bike I'd opt for #2 first and #3 second (I like less pedestal)
If your Pad X is 541 (if, mind you) then the two most realistic options are these:
1) you have a 90mm stem with the bracket forward and the arm rest hole rearward (result is 530mm)
2) you have the 110mm stem with the bracket forward and the arm rets hole rearward (result is 550mm)
It's important to note something here... #2 is the absolute longest this bike goes: 110mm stem + bracket going forward and arm rest dangling out front as far as possible. And #1 is nearly the longest this bike goes.
So your question is essentially.. should I sell the 56 and get a 54 'cause the post is low in the frame? My answer is if (this is the big "if") if your Pad X is really 541 then don't get a 54 because the longest Pad X you can get on that bike is a 540, that's your number and if you ever want to adjust out a hair you cannot. Also, max Pad Y on a 54 is 715, that's only 9mm higher than where you are now. Sure the post might be out of the frame a bit more but you are painted into a corner maxed out on the size 54.
So...I'd like to know 3 things:
1) What is the actual Pad Y you are currently riding?
2) What is the actual Pad X of what you are currently riding?
3) Do you like that position in terms of comfort, power, aero?
So, if you could get the bike on a level floor. Roll it up to a wall that is at a 90 degree angle to that floor so the front tire is touching the wall. Then line up the front wheel with the frame and measure & math out these two things:
1) measure from the floor up to the center of the bottom bracket (A). Measure from the floor up to the top of the arm pad (B). Subtract A form B and tell me Pad Y.
2) measure from the wall back to the back edge of the arm pad (A). Measure from the wall back to the bottom bracket (B). Subtract A from B and tell me Pad X.
Get back to me here and let's see what's really happening.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
