Andrew Coggan wrote:
Jerryc wrote:
There is lots of information that suggests that VO2 max is muscle specific and will vary sometimes widely between the muscle used in the test.
Sorry, but this statement is simply incorrect. If you can't achieve the same upper limit to VO2 using a particular exercise modality, then that's not VO2max, just a VO2peak.
I assume that Jerry is talking about VO2max changes between modalities (e.g. cycling, running and nordic skiing).
Altering the active muscle mass will change peak oxygen uptake.
I believe AC is saying that within one exercise modality (e.g. Cycling) there is a true max with lesser values being referred to as Peak. This varition should not be construed as changes in max.
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
I also give Training Advice via http://www.ForeverEndurance.com
The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
xtrpickels: Apr 7, 15 8:00
