I have been struggling to adjust to an ISM PN 2.1 for the last 6 months and I think I am finally done trying to make myself fit the saddle. Before my setup is critiqued, let me say I have had a professional fit with the saddle followed up with micro adjustments in height (lower), angle (slight downward tilt) and position (further back)... my issue: nothing I do prevents chafing on my groin / inner thigh area. I am convinced the saddle is too wide and I need a narrow nose saddle.
This article: https://www.slowtwitch.com/...The_Front._6365.html was quite useful in highlighting similar issues I face with the width of the PN 2.1, which at 2cm from the front of the nose is 65mm wide. Does anyone with similar problems in the past now ride a 55mm (or less) nose width saddle?
Similar posts I have searched from years ago recommend the Bontrager Hilo Comp, but I don't think the nose widths are any less than the PN 2.1.
My fitter is recommending the Selle SMP T3 which appears narrow but I can't find any details online of the actual nose width. Can someone with this saddle measure it?
Right now I am thinking of going with the T3 unless I can find some alternate suggestions?
Thanks in advance
Thanks in advance
