Hey all, looking for some assistance with front brake setup. Just about done building my new frameset, but having issue with front brake caliper.
So when I setup the triangle pully thing that attaches to the cable, and I have the caliper arms kind of in their default all the way out position, things work OK. But if I then use the small outside allen screws to try to adjust the arms in towards the rim to get them close enough for good braking, the caliper rollers seem to lay on the triangle uneven, and the cable pulls it up at an angle, causing only one arm to move properly.
Even if I try to adjust both caliper arms the same amount, the right one (looking at it from the front) doesn't get moved properly from the triangle movement.
Clear as mud??? Anyone advice? I could try to post a video of it if that would help...
