MattyK wrote:
rruff wrote:
I have no idea what this means.
I am curious how every other wind tunnel plot shows less drag as yaw increases, but this is the opposite.
Armchair aerodynamicist: if something like the texture/tread pattern on say Continental tyres compared to others seems to have a notable benefit, why doesn't anyone apply this on the texture of the rim, say when the inner edge is leading?
I could type out a lengthy explanation but... I don't think I'll do it correctly. Here's a quick but not entirely correct explanation: it has to do with the axis and speed in which drag is computed and then normalized. For example, look at the vectors in a 50kph wind tunnel test with a (for demonstrative purposes) 45 degree yaw angle. What's the speed in the forward direction? What's the cross wind? How much side force do you have? How much drag do you have in the forward direction? Most people are used to looking at charts that show drag in the forward direction. This style chart shows total drag.
A common misconception is that you're actually more aero/faster in a mild crosswind versus no crosswind at all because practically every bike frame and wheel set shows lower drag at 10 degrees of yaw than 0 degrees. So let's work in reverse: you're going 20mph and you're consistently hit from the side by a 20mph crosswind. If you were to recreate this condition in the wind tunnel, how would you orient the wheel and at what speed would you run the tunnel? How would you attribute the resulting total drag to the respective vectors (crosswind force vs drag in the direction of travel)?
I'm really kind of hoping someone who's better at explaining this sort of thing chimes in with force vector diagrams to explain this because I'm struggling to do this in written form. For what it's worth, this isn't the first time data has been published in this form. It's rare but it's not the first time.
With regards to your idea regarding texturing the inside edge of the rim, it's a good idea but I suspect nobody has tried for fear of running afoul of Zipp's patent.
