Re: Let's see your ride! [DuGuy] [ In reply to ]
My baby...felt f4 road bike with profile ffc seatpost, profile carbon stryke aerobars with cobra wing base bar, vision brakes, shimano ultegra/dura ace mix, look keo ti carbon pedals, and zipp 606 wheelset with conti attack/force tires.
For the ladies among us (race set up):
naked...
and the profile pic (the only one where my camera didn't decide to suck):
____________________________________________
Hungry for tri!
I finally added a road bike to the stable. It's not a Cervelo...nor is it super-bling'd. But then again, how many other SRAM Red Bikes do you know of for less than $2K?
I'm still tweaking the position and will probably swap out the seatpost. And, yes, I'll cut down the steerer tube soon. ;)
I'm lovin' the frame, groupo, and wheels. You just can't beat Neuvation for value.
"100% of the people who confuse correlation and causation end up dying."
Re: Let's see your ride! [MOP_Mike] [ In reply to ]
In Reply To:
It's not a Cervelo[/quote]and yet it should ride really similar to one as it's made (according to john & dan) side by side and in the same asian factory that makes some of the cervelo frames AND it has the identical geometry as the soloist.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Michael in Fresno
"Do you spend time with your family? Good. Because a man that doesn't spend time with his family can never be a real man" V. Corleone
Re: Let's see your ride! [Tribato] [ In reply to ]
Could be, but that doesn't necessarily mean they're using the same tubing, which might make a big diff.
Re: Let's see your ride! [TriUno83] [ In reply to ]
true. they're using similar but not identical tubing (cervelo's aluminium SmartWall is proprietary) so it won't be identical but i submit it's "close enough" for the majority of riders...especially if you can get SRAM RED for less than 2K. i think having a top end component group may offset any perceived difference in ride quality.
Michael in Fresno
I haven't ridden a Soloist, so I can't compare the ride. But, yes, the geometry is identical, though the Soloist offers an aero seattube and a narrower downtube profile.
The frame welding, finish, and assembly are first rate. And, the internal cable routing is clean and operates smoothly.
I wanted a nice comfortable and reasonably fast bike for group rides, and minor build and aero considerations just were not important. If I want to fuss over speed details I'll ride my Titanflex @ 80 degrees STA...with latex tubes, Jet Disk+Jet60, aero helmet, etc., etc. ;)
Re: Let's see your ride! [S~] [ In reply to ]
Here is my silly bike
It is a leader frame ($150), wolf CL fork ($100), Ultegra kit ($500), random other stuff (seatpost, bars, stem, etc. $300), FP80 Wheelset (from Wheelbuilder.com) including wireless PT ($2000) - Total ~3000 dollars. I would venture its one of the fastest $3000 bikes (*with Power meter) out there. I have moved the bar extensions in to a "custom" width (skinnier than standard). Also the brake and shifter cables are "custom" to expose less cable. I run 20mm wide tires @ 110-120 PSI.
I did the Wyckoff TT @ 23 mph, being held up quite a bit of the time at a wopping 226 watts and this is not too flat of a course.
Re: Let's see your ride! [ In reply to ]
girlfriends new bike
BRAND NEW 650 P3
yes its a wonky stem, but I assure you her position is Torbjorn and Slowman approved. Shes just got LEGS.
Re: Let's see your ride! [jackmott] [ In reply to ]
make over
These are my team bikes:
Race ready tri bike...
http://farm4.static.flickr.com/...18335_e4df0e9d63.jpg
Race ready road bike
http://farm3.static.flickr.com/...74014_5e699ec871.jpg
Owner of a few Speed Concepts since 2011.
Re: Let's see your ride! [Tri Slow Poke] [ In reply to ]
you don't have any pedals!
Re: Let's see your ride! [swimfan] [ In reply to ]
steerer needs to be cut.
____________________________________________________________
Link to my photography
http://davidsavoiephotography.blogspot.com/
http://davidsavoiesports.blogspot.com/
Wife's new bike - MissP's Cervelo P3 ready to roll at Ironman Lake Placid( 4th fastest woman's bike split and 5th place overall)
Steve Fleck @stevefleck | Blog
Re: Let's see your ride! [Fleck] [ In reply to ]
your big ring is crooked.
In Reply To:
I want my bikes as light as possible!!!!
This one is mine. :D
Re: Let's see your ride! [peterwong] [ In reply to ]
Let's keep the Cervelo lovefest going!!
Re: Let's see your ride! [rmcboy] [ In reply to ]
Please tell me you don't ride your bike with the saddle like that.
here's my new ride, love it.
Re: Let's see your ride! [trice9] [ In reply to ]
Re: Let's see your ride! [Punch] [ In reply to ]
Since the picture was taken, I've shortened the aerobar length slightly and added a zero setback seatpost to give me a slightly more aggressive position.
Re: Let's see your ride! [itrislow] [ In reply to ]
