Re: Let's see your ride! [DrPete] [ In reply to ]
Sounds like a good plan...assuming you have a personal coach. If not, then the 5k you were gonna spend is for nothing. Just my opinion.
_______________________
Duke Liver Center Half 9/27/09
Sponsored by:
Student Loans, Mastercard
Re: Let's see your ride! [IdlersRest] [ In reply to ]
In Reply To:
That's in the plan too.
I'm an inexperienced triathlete but an experienced roadie, and I fully understand the distinction between making purchases that will increase your speed and buying cool stuff for your bike because it's just so damn fun. :)
Steel´s real.
1995ish Gitane Mach 310
Columbus Gara tubing.
Improvised FF tri post and Fisik saddle
Mavic Cosmic Expert 30mm clincher wheelset with a Wheelbuilder cover
Ritchey Probiscus bars with NOS GripShift 7-speed.
Shimano 600EX (?) groupset, Biopace crank. Keo pedals.
´Get the most aero and light bike you can get. With the aero advantage you can be saving minutes and with the weight advantage you can be saving seconds. In a race against the clock both matter.´
BMANX
Re: Let's see your ride! [Barchettaman] [ In reply to ]
My 2007 Specialized Tranistion Pro was stolen a couple of weeks ago so this is my "new" bike. I bought the bike minus wheels from another STer.
The rear wheel is a homemade disc converted from a Mavic Aksium training wheel. I cut the discs from flat ABS plastic sheets and bonded them to the wheel with Spray foam insulation. And yes it does make the ominous rumbling sound just like a "real" disc.
http://i39.tinypic.com/97l74w.jpg
Re: Let's see your ride! [paul_tx] [ In reply to ]
In Reply To:
Fascinating... Do you have more pics of this? I'd be interested in more details.
"I can eat 21 plus a deep-fried turkey!"
Re: Let's see your ride! [Mr. Blonde] [ In reply to ]
I don't have any more real close up pics but I can get some. It's not the prettiest thing up close. My next one will be nicer looking and hopefully lighter.
When I have time I'll detail what I did, it's not hard or even as messy as you might think, anyone can do it if they can find sheets of ABS plastic that's not too thick (heavy).
Re: Let's see your ride! [TriCat13] [ In reply to ]
Here's mine just back from a 56 mile ride as a warm up for Florida 70.3. Too windy to run a disk around here for the most part.
Re: Let's see your ride! [ In reply to ]
My new ride. Slightly used.
http://gbsps.freeshell.org/.../Cervelo_P2SL_ME.JPG
And the previous owner. Anyone recognize this guy?
http://gbsps.freeshell.org/...000/Cervelo_P2SL.jpg
Re: Let's see your ride! [inaba116] [ In reply to ]
Wow does not get nicer than this, crazy nice. Enjoy.
Re: Let's see your ride! [DuGuy] [ In reply to ]
New pictures of the current stable.
Cervelo SLC - New custom full aero chainrings. Yes both rings are full aero. Currently 13.68 lbs.
Giant TCR Aluminum - Upgraded to Sram Force. Higher handlebar position for longer rides and chainring off of the SLC. 13.87 lbs.
Pedal Force MT XC - Upgraded to ZTR wheels and XTR disc brakes with Ashima rotors. Weight of build is currently at 18.54 lbs and I am playing with the rear derailleur to see if I want to run a 12/27 on the back matched up with my 44t/30t front.
Giant TCR Aluminum - Winter/Trainer ride. 34t spiderless chainring and set up as a 1 X 10. Custom shifter mount for something different but it works amazingly well. 15.06 lbs.
Re: Let's see your ride! [nujeff] [ In reply to ]
In Reply To:
[/quote]
Just finished assembling my new frameset with John Cobb approved 165mm cranklength, slowman approved 80*+sta, reverse pull levers, pd saddle, tool bottle, 50X34 chainrings, 12/27 cassette, and long cage rd, and jackmott approved pad risers...
And i have hairy legs to boot- Look out 'Hills of Houston' now.....
Thanks to Cervelo Customer Service and my Local Cervelo Bike Shop
- Jeff
goals, personal:
- under same username post st rr of Kona m80-84ag mop, tail end of the dopers finish
- shoot age from tips on par 72
- beat SuperDave in one-on-one
all within single wk- Viva Chopin, Fryderyk; Faulk, Peter; Helmsley, Sherman; Palillo, Ron; Rogers, Fred McFeely; Sanford, John Elroy; Snuka, Jimmy- and the water bottle isn't half fuller on the other side
Here was my set up for IM CDA
In Reply To:
Just finished assembling my new frameset with John Cobb approved 165mm cranklength, slowman approved 80*+sta, pd saddle, tool bottle, 50X34 chainrings, 12/27 cassette, and long cage rd, and jackmott approved pad risers...
- Jeff
Why are your handlebars pointing down?
Re: Let's see your ride! [Raptor] [ In reply to ]
I saw it on a bike manufacturer's website once.
It's a bit more comfy for me, plus I don't care for how upward turn base bars look with the brakes pointed downward.
Just a personal thing...
goals, personal:
Re: Let's see your ride! [Roughster] [ In reply to ]
very nice- what kind of bento is that?
goals, personal:
No wonder you didn't KQ, you were dragging a f'ing convenience store!
Its taken about a year to save up for all the parts, but I finally got it together (today!). She's fast (a lot faster than the roadie on training wheels i was riding at least), and im working on the engine, but I dunno if I'll ever quite live up to its legacy..
In Reply To:
That is the Fuel Belt Aero Bento. Worked great!
for downforce on technical courses
Re: Let's see your ride! [jfanny88] [ In reply to ]
One of the most unique in this forum.....
Either you're sponsored by Fuji but hate the D6 or you hate Cervelo.....
Re: Let's see your ride! [campled] [ In reply to ]
Armstrongs bike when she raced for Lipton before lifeforce/test team.
Thats a heck of a picnic you packed there. The only thing missing is the tablecloth!
yup, she donated the frame to a bike shop and I picked it up on ebay
Just swapped to RED, picking up from the LBS this afternoon!
