Any others using shims to help fix up leg length problems? Just fit 2mm to my left cleat.
Before fitting, I would regularly see 50/50 left,right power from my powertaps. Sometimes it would report left being a little stronger.
Since adding the shims, I am often seeing 47-49 on the left. Surprised it could affect that much but would like to try and fix
Ive always had my saddle height set so my left leg locks out when heel is on the pedal. Now that Ive fit the shims, I presume I should probably add 2mm or use my slightly longer right leg to set the saddle height?
